Subwoofer / Interior Lighting Install (OEM)
Here's what Derek from Bazooka replied...
That harness works for a couple of different cars.
Some cars, like the Scions, have a remote turn on lead coming out of the head unit.
Some cars, like the Corrolla, RAV4, and Highlander, don't.
If it's available, we use the head unit's signal to turn on the amplifier in the Subwoofer, by tapping into option 1, the blue wire. When it's not, we use option 2, the red wire, to turn the subwoofer on when the car's ignition is turned on.
Using a remote turn on scheme stops the subwoofer from being on all the time, which would drain the battery through parasitic draw. Also, turning it on and off with the Head Unit usually eliminates turn on and off pops, but it's not 100%.
The wire colors are CEA standard, meaning that the red wire is ignition controlled 12 volts, and the blue wire is power amplifier. Blue with white is usually antenna remote, which is only active when the tuner is on--not when a CD or tape is on--so the red wire is still a viable option in those vehicles.
Question regarding wiring the switch..
What gauge/type of wire do you use to lengthen the blue/white power wire?
What type of connector do you use at both ends?
Help appreciated- I just tried with something which is obviously the wrong gauge/kind of wire, and was scared i'd killed it, until I managed to mangle the wire i cut back to itself with electrical tape.
^^ thanks for the response. I did some guessing and discovered that the wire is 18 gauge stranded, so I got some of the same kind of wire to lengthen it as well as some crimp plug connectors- now its working like a charm.
Originally Posted by Mikeydizzle
question about the lighting... how did you wire them? did you just tap into the 12v or did you wire it from a separate fuse?
^Sorry, I thought you were referring to the factory light kit which is all LEDs. You could always wire the neons to the light inside the storage area in front of the shifter. That way they'd be on whenever your dash lights are on.
i am looking to install the factory sub with an aftermarket radio which has a preamp RCA output. will i need an adapter or wiring harness to connect the sub to the RCA preamp? if so it would be helpful if sum1 could let me know what type. thanks...
dont get a bazooka... please... it cannot be very cost efficient. and only a couple inches up from the factory sub anyways? once again please don't do this...
if you get a sub save up and do it right
Alpine R 12" best bang for the buck and the second best 12" made today IMO
-retail: $230 each alone -ebay: plenty of factory sealed sellers for $120 shipped
Alpine/Pioneer Amp rated at 500 watts, great units (forget the model names) superior quality, easily bought between $80-$180
sealed (no ported please) box $30-$100 max, for a 10" sub, jigsaw it to fit a 12" or just get a 12" which can still be done easily between $60-$120
total = roughly $220-$300 easily done all brand new parts
custom fit bazooka sub = $264 on the site you listed.
Bazookas are okay but i don't think the sound can compare to even a rockford fosgate much less an Alpine or Audiobauhn
btw, the LEDs... $120 (retail $150)??? wow ... www.oznium.com and relish in the prices.
i'm not a sales rep i'm just someone who does product quality research.
EDIT: fixed prices
EDIT: fixed prices
