tC Tech and DIY Info for the Scion tC
Transmission Flush (Automatic, Eneos ATF)
Old Jul 8, 2008 | 09:02 PM
svencarlson07's Avatar
im turbo and because of the intake pipe its blocking the the dipstick
Old Jul 8, 2008 | 09:35 PM
himynameischris's Avatar
Royal Purple Max ATF from http://store.summitracing.com/egnsea...nresults=false
, is that ok? it would be my guess any ATF fluid works for the car but this im guessing isnt "covered by warranty" correct?[/code]
Old Jul 8, 2008 | 10:54 PM
KINGxOFxSKA's Avatar
Unique Scionikz
No, not all ATF will work with our car. It doesn't say anything about Toyota Type-IV which is what our car requires.
From the Summit Racing website:
"Royal Purple Max ATF is a synthetic, high-performance, long life, multipurpose automatic transmission fluid. It is recommended for all automatic transmissions requiring Ford Mercon or GM Dexron III transmission fluids. "
Doesn't say anything about Toyota Type-IV
Old Jul 9, 2008 | 12:35 AM
tcchris38's Avatar
This is stright off of royal purple's website.
"Toyota - Type T, Type T-III, Type IV-- Max ATF"
They do recomend it for our cars!
Old Jul 9, 2008 | 02:08 AM
booo yah thanks my man, i already ordered it =] ha
Old Jul 9, 2008 | 02:21 AM
tcchris38's Avatar
I was thinking about ordering it to but I didnt have enough time to do it bc I was pushing to have it done so I just went and got ATF for the dealer. But himynameischris if you could let me know how the max ATF works that would be great!! Thinking about getting it but would like to see what you think of it when you get it in your tranny!
Thanks,
Chris
Old Jul 9, 2008 | 03:53 AM
Unique Scionikz
nice find... i didn't bother checking the royal purple website.
Old Jul 9, 2008 | 10:39 AM
carcandymotorsports's Avatar
We got all ENEOS oils in stock- FREE Shipping
http://www.carcandymotorsports.com/i.../cPath/404_406
Greg
Old Jul 9, 2008 | 10:05 PM
wow summit is fast, (and close) i just got the tranny fluid TODAY, ordered yesterday recieved today A+, ill install it tonight and will be cruiseing around ill give some feedback!.
*edit* fluid was installed and the car ran beautiful, it shifts much smoother and harder, my friend was even complimenting it after it was done.....
Old Aug 19, 2008 | 06:45 AM
krazyscion's Avatar
wow great write up...dealer wants to charge me... $190 for that.. rip off!
Old Aug 19, 2008 | 06:50 AM
andino's Avatar
You can also use Amsoil Synthetic ATF
Old Aug 19, 2008 | 03:53 PM
BZinn1's Avatar
Thanks for the write up.......I wilhave to check out the Eneos Tranny fluid when I do mine......I like to change it out every 20,000 that way the slush box lasts a long long time.
Old Sep 6, 2008 | 01:05 AM
Blacktoast's Avatar
Default I wouldn't use anything but type IV
I wouldn't use anything but type IV. It can void your warranty. Also the dealer charges X amount of $ because we at least my dealer flushes all the old fluid out. A drain and fill will not take out all the old fluid. There will still be a good amount of dirty fluid in the tranny. Just like a drain and fill on a radiator will not take out all the dirty fluid in the cooling system.
Old Sep 6, 2008 | 09:30 AM
sciontc_mich's Avatar
yeah but go ahead and flush a valve body, not the best idea for them. No matter if a "dealer" said it was good. Also power flushing an aluminum radiator, not a good idea if you don't want to have something rupture. Aluminum = Thin = No flushing, just drain.
I would just drain and refill like Toyota recommends (even in the service manual they only recommend draining). At how often people are draining it, like every 15k to 20k miles you have nothing to worry about. I would worry about flushing the entire trans with a pressure machine! ouch!
Old Sep 20, 2008 | 10:34 PM
Blacktoast's Avatar
Sorry bro,
Your wrong. At least on any of the machines I have ever used. The coolant flush machine won't even run if the pressure is to high. The trans flush machine puts lets pressure on the trans then it gets during normal use.
Old Oct 5, 2008 | 02:03 AM
tkevin07's Avatar
hey guys for info toyota's tranny fluid is Dex-III if u look at the back of the bottle, its honda that is really strict on their tranny fluid anyways anyone have a writeup on auto tranny's tranny filter change like how does it look when i pull it off?
Old Oct 5, 2008 | 02:14 AM
jsingh's Avatar
OhioScions
thanks for the diy!!
Old Oct 5, 2008 | 03:04 AM
Wutachampion's Avatar
Thanks man!
Old Oct 9, 2008 | 06:44 AM
kriswawa's Avatar
Hi
for any miles - have to be ATF oil changed?
for any miles - have to be motor oil changed?
maybe some one have photos - how to chnage oil filter?
thanks in advance
www.scion.pl
Old Oct 9, 2008 | 06:48 AM
drewsquared's Avatar
change it at 30k
