xB Tech and DIY Info for the Scion xB
Gauge Lighting: Changing color
Old 07-28-2007, 08:35 AM
  #81
detiber's Avatar
The Gauge cluster in the xB uses PLCC2 sized LEDs. If you want to change out the LEDs behind the Clock, they are 1206 sized.
You can get the PLCC2 LEDs from Oznium (http://www.oznium.com/plcc-2).
As for the 1206 LEDs, you can get them from most any electronic parts supplier I personally use http://mouser.com.
Just make sure that the LEDs have a mcd of at least 100 (brightness).
detiber is offline
Old 08-09-2007, 09:54 PM
  #82
crxlurp's Avatar
how many leds does the gauge cluster use? i am going to order some. and then i need 4 for the odo and clock right?
crxlurp is offline
Old 08-10-2007, 01:51 AM
  #83
detiber's Avatar
You will need 20 PLCC2 LEDs and 4 1206 LEDs for a manual. I believe there are 8 extra PLCC2 LEDs needed if it is an automatic.
detiber is offline
Old 08-10-2007, 03:17 PM
  #84
crxlurp's Avatar
20 just for the guage? or is that for all the indicator light as well?
crxlurp is offline
Old 08-10-2007, 03:36 PM
  #85
detiber's Avatar
Sorry, 20 all together for the gauge and indicator lights. There are only 3 for the gauge face itself.
detiber is offline
Old 08-12-2007, 06:48 PM
  #86
MN Scions
Murbyrne's Avatar
cool, but it seems like the color fades. Has anyone done it with green yet?
Murbyrne is offline
Old 03-18-2008, 04:33 AM
  #87
martin_barrera's Avatar
Default Odometer Miles
A and B miles...What does this mean?
martin_barrera is offline
Old 03-18-2008, 07:43 PM
  #88
CharredEarth's Avatar
Default Re: Odometer Miles
It means the Odometer trip distances. There's 3 settings on them, straight Odometer, which is how many miles TOTAL you've gone in your car, Trip A and Trip B for keeping track of how far you can get on a tank of gas/distance travelled on a trip, etc.
eg: looking at your odometer, press the little stick that pokes out of the cluster beside/below it (depending on which vehicle you're driving). You'll see the odo change between Odometer, Trip A, and Trip B.
The trip A and B Odometers can be reset to 0, where the straight Odometer cannot.
Hope that helps!
CharredEarth is offline
Old 03-19-2008, 03:17 AM
  #89
Default We'll see...
Modified mine today...I decided to go with blue. It's still light outside so i'll see how it turns out in an hour or so. Thanks a bunch.
Q: How long does the sharpie color last before it fades off?
Old 03-23-2008, 09:07 AM
  #90
Default !!!
I modified my gauge but it seems that I put the hands' back incorrectly. I mean....I filled up my tank and it shows up as 3/4 full. Any one have the same problem? How do I fix it???
Old 03-23-2008, 01:28 PM
  #91
chadfo's Avatar
Default Re: !!!
Go to the bottom of this page and you'll find instructions.
http://www.forcespeed.com/XBInstall/XBInstall.htm
chadfo is offline
Old 03-24-2008, 12:19 AM
  #92
Default Thanks "chadfo"
I fix it! Really easy...took me a couple of minutes. Thanks. Stay up!
Old 10-04-2010, 04:47 AM
  #93
itscurtsk's Avatar
i was able to do it for the xA. it's a little bit different but pretty much same concept. basically keep removing the top layers which are very easy to take off. the rpm and fuel needle i just put it on Empty and 0. the mph needle was a bit tricky. my last resort which worked, drive without the speed needle for like a block, park it, place the needle onto 0 and it should work. if not, then turn off your car after placing the needle and turn it back on. here are some pics:
itscurtsk is offline
Old 10-13-2010, 05:28 PM
  #94
Rucker's Avatar
good stuff! this took all of 15 minutes to do and came out SICK
Rucker is offline
Old 10-13-2010, 07:49 PM
  #95
itscurtsk's Avatar
post up pics and say what color sharpie you used. i used regular blue.
Old 10-13-2010, 07:57 PM
  #96
Rucker's Avatar
cant get my pic to post. i used the dark blue as well, i'll keep trying
Rucker is offline
Old 10-13-2010, 08:03 PM
  #97
Rucker's Avatar
[IMG]http://www.flickr.com/photos/12621805@N05/5078943606/http://www.flickr.com/photos/12621805@N05/5078943606/
Rucker is offline
Old 03-16-2015, 05:17 AM
  #98
lovemyxb333's Avatar
For the clock light do I need the standard 1206 leds or the 1206 diodes
lovemyxb333 is offline
Old 03-19-2015, 11:22 PM
  #99
SquallLHeart's Avatar
hmm? LEDs are diodes.
Light
Emitting
Diodes..
yes 1206 sized for a 1st gen xB
SquallLHeart is offline
Old 04-01-2015, 03:59 AM
  #100
Light
Emitting
Diodes..
Thanks I had a duh! Moment. The way the description was written out on the site I bought them from threw me off for a minute.
Quick Reply: Gauge Lighting: Changing color
