tC Seat Belts are Locked???
Old May 3, 2007 | 08:17 PM
ilovemytC's Avatar
Default tC Seat Belts are Locked???
There's a guy who got into a rear-end collision and his seat belts are locked. Anyone know how to disengage seat belts?
Old May 3, 2007 | 08:52 PM
gizmokat's Avatar
the mechanism might be damaged?
like they're locked as in they won't go all the way back in or won't come all the way out?
a sensor might have gotten retardoed...
Old May 3, 2007 | 08:54 PM
gizmokat's Avatar
Found this:
And check the label on the belt - if it says "Replace" it has been in a
severe enough accident to pull out that tag, then it is no longer useable.
http://groups.google.com/group/alt.a...b1a486e8f00db0
Old May 3, 2007 | 09:24 PM
ilovemytC's Avatar
thanx! I hope that helped.
Old May 3, 2007 | 09:29 PM
LostCause's Avatar
Default locked
Hey guys
The seatbelts not damaged. Its a safety precaution.
When your in an accident theres like a explosive charge in the seatbelt that fires of little pellets within the belt mechanism. Locking it in place. It happened to me too. If you go to an autobody repair shop they will remove the pellets for you. But the mechanism will not detonate in the future, either have it repaired or if your finiki about those things youll have to buy new ones.
Old May 3, 2007 | 09:40 PM
gizmokat's Avatar
wierd, detonate! haha man that sounds slightly scary ;P
wow great info
thanks!
Old May 3, 2007 | 09:43 PM
nodsetse's Avatar
Replacing seatbelts after an accident has been recommended since before they had the mechanism you described. When seatbelts do their job during an accident, the material and stitching is stretched, such that they're weaker than intended and might fail if you had to depend on them again. Now I've always been skeptical about that, and I think they might be ok, but that's the main reason replacement is recommended.
So I take issue with your statement, because while it is a safety precaution, whether or not they're damaged is debatable.
Old May 4, 2007 | 06:19 PM
ilovemytC's Avatar
Default Re: locked
Hey guys
Good info!
Old May 4, 2007 | 07:56 PM
paul34's Avatar
Aren't the explosive charges for the pretensioner? AFAIK they're intended to reduce the shock force on your body a bit, not really to "lock" the belt in place
But yes, they're like airbags... once it goes off, it has to be replaced.
Old May 4, 2007 | 10:27 PM
LostCause's Avatar
i dont think so....i was there when the mechanic opened up my seatbelt.
Theres a cog and the explosive shoots little metal ***** in the gaps of the cog, effectively locking it in place. I also heard that this way insurance companies can see wether you were wearing your seatbelt when you crashed.
Old May 5, 2007 | 06:36 PM
Bozuzu's Avatar
yeah dude you'll want to get those replaced, there's an explosive discharge in an accident and it's only good for one time, just like an air bag, they don't repack them like a parachute, haha!
Old Dec 31, 2008 | 01:20 AM
OuTsIdAz2k's Avatar
wow thats funny cause right now i have the same problem where my seatbelts are locked but not like i've been in an accident... I tried pulling them and they are stuck in the resting position before i get in the car... does anyone know how to unlock that ?
Jayrdee
Oct 15, 2015 03:38 PM
wejarrell
10
Aug 5, 2015 09:19 PM
x2x3
Aug 4, 2015 09:07 AM
bmxScion
Jul 23, 2015 12:07 AM
