Backseat Wires
Old May 6, 2007 | 03:15 AM
PikesPeak's Avatar
Default Backseat Wires
I lifted the carpet behind the back seats. There are red and black wires with electical tape on the ends. Also, a pair of RCA connections. Is this for an amp or subwoofer?
Old May 6, 2007 | 03:20 AM
Zebman's Avatar
Did you buy the car used? I can't remember if the RS1's came with the factory sub or not. Even if they did, that means that yours isn't there, or somebody had an audio system in it.
Old May 6, 2007 | 03:23 AM
PikesPeak's Avatar
Yes...bought it used. I don't see any other signs of speaker or amp installs.
Old May 6, 2007 | 03:26 AM
Zebman's Avatar
Yep, that's likely the wiring to the factory subwoofer.
Old May 6, 2007 | 03:45 AM
Scionizer07's Avatar
No, its not factory. Scion is not going to put electrical tape on the ends of wires and leave them under the seat. It was from an installed amp. You might be able to use it if you want to put an amp in, but I'd redo it all myself to be on the safe side...
Old May 6, 2007 | 02:32 PM
Zebman's Avatar
The person who tore out the sub to sell on ebay HOPEFULLY would put electrical tape on the power wires to keep them from shorting, and his battery exploding.
I'm pretty sure it's the factory sub wiring because last time I checked, large gauge power wire was wrapped in PVC, not black and white shrink (which is what i'm inferring from his post). I'm not sure if it used RCA inputs though. I may be wrong.
Is the stock head unit still in the car?
Old May 6, 2007 | 04:16 PM
PikesPeak's Avatar
Yes....it's stock. Definitely looking at replacing that.
Old May 6, 2007 | 04:19 PM
bsmith11's Avatar
someone had a system in there and took it out...Factory NEVER uses RCA's to transfer sound, they like hi-level inputs rather than low level...and if you have a factory stereo u might wanna check behing it and see if someone has left you a line converter back there.....since there are RCA's in the back.
Old May 6, 2007 | 06:01 PM
SquallLHeart's Avatar
hmm.. probably took that thing out..
and yea.. the RS1 didn't come with a sub... they started the mini 6" subs in the RS2
Rob54Monty
Feb 3, 2023 08:26 PM
pjl52
Aug 13, 2015 02:38 PM
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
