RPM at 60 and 80 MPH with 5 speed
Old May 6, 2007 | 12:58 PM
forby's Avatar
Default RPM at 60 and 80 MPH with 5 speed
My biggest comlaint about the Xb original is that at 80 MPH with stock tires and a 5 speed, the RPM's are at like 4000!!!
Can someone clue me in as to the numbers on the new Xb with a stick?
I realize that the 1.5 need more RPM's (HP) to overcome the air resistance at those speeds. My wifes Honda EX V6 with an auto is at like 2600RPM's at 80!
Old May 6, 2007 | 03:22 PM
stew32's Avatar
Since it's the same engine as tC, I assume it's the same manual trans and numbers would be the identical. So what's that? Car and Driver says 21.6 MPH per 1,000 RPMs in 5th gear for a tC. So 2,700 RPM @ 60 MPH, 3,700 RPM @ 80?
http://www.caranddriver.com/roadtest...-tc-page4.html
Old May 6, 2007 | 04:18 PM
Bigfieroman's Avatar
The xB actually uses a little bit taller tire than the tC, and that has an effect.
I come to ~2750 (tC close to 2800) at 60mph and about 3660 at 80 mph.
I was under the impression that the old xB ran at something like 4500+ at 80 mph?
Old May 6, 2007 | 05:19 PM
stew32's Avatar
1st gen xB with manual is approx 4,000 RPM at an indicated 80 MPH. Still really high though.
Old May 6, 2007 | 05:38 PM
Tomas's Avatar
Admin Emeritus
The figures for the Original xBs have been posted and discussed many times:
AUTOMATIC:
2560 RPM @ 60 MPH
2990 RPM @ 70 MPH
3410 RPM @ 80 MPH
MANUAL:
3070 RPM @ 60 MPH
3580 RPM @ 70 MPH
4090 RPM @ 80 MPH
Checking the dealer booklet for the new xB2, I get the following:
Tire size: 205/55R16
Final drive ratio: 4.235M / 2.74A
Top gear ratio: 0.731M / 1.020A
and that means:
835 * 4.235 * 0.731 = 2585 RPM at 60 MPH manual
835 * 2.74 * 1.020 = 2334 RPM at 60 MPH automatic
(rev per mile) * (final ratio) * (top gear ratio) = (engine RPM at 60MPH)
So, for the manual transmission xB2:
2585 RPM @ 60 MPH
3015 RPM @ 70 MPH
3445 RPM @ 80 MPH
plus or minus 10 RPM.
For the automatic transmission xB2:
2335 RPM @ 60 MPH
2725 RPM @ 70 MPH
3115 RPM @ 80 MPH
(Damned tpyos.)
Old May 6, 2007 | 07:25 PM
OldYeller's Avatar
4000 is a couple of thousand+ below redline. Is it the noise you don't like or do you think it is wearing out the engine. These engines are made for high revs.........
Old May 11, 2007 | 01:08 PM
forby's Avatar
Thanks for all the replies....
I have been busy lately and unable to repond to this thread.
I am concerned about the noise mostly. At 80Mph it seems like I'm in a blender!!!
The new Xb seems to be about 650RPM's lower!!!!
That should make for a really quite drive.
Old May 20, 2007 | 10:44 PM
Ethereal_Dragon's Avatar
It's about the gas savings too... at least thats what I would think...
Old May 21, 2007 | 01:15 AM
Tomas's Avatar
Admin Emeritus
The manual transmission '08 xB2 is wound just a little bit tighter than the automatic transmission '03-'06 xB.
Tom
Old Jul 12, 2007 | 12:56 PM
chadfo's Avatar
You don't have to worry about noise in the XB2. It's MUCH quieter than the XB1. With the stock muffler you can't really hear any engine noise once you level off at a given speed.
Fisqual
Sep 22, 2015 05:51 AM
mgaines
Jun 14, 2015 11:39 PM
Steelerfanmatt07
Jun 5, 2015 03:07 AM
annika
Mar 16, 2015 06:36 PM
Wide_tC
Jan 15, 2004 01:00 PM
