Tire question for 19x9.5" rim?
Old May 10, 2007 | 07:57 PM
peter_x9's Avatar
Default Tire question for 19x9.5" rim?
I want to buy a staggered 19x8.5, 19x9.5 wheel set. Can I put 225's on the wheels? or do I have to at lease to 235 tires?
Thanks
Old May 10, 2007 | 08:03 PM
Neothin's Avatar
or at least a 275 haha
Old May 10, 2007 | 08:31 PM
bkuhl's Avatar
225's would be a bit narrow for that width of a rim. To be honest I don't believe you can even go that small on a 9.5".
I'd recommend 235/35/19 on the front 8.5's and 255/35/19 on the rear 9.5's.
Old May 10, 2007 | 09:05 PM
Neothin's Avatar
195mm = 6.5", 7" and 7.5"
205mm = 6.5", 7" and 7.5"
215mm = 7", 7.5" and 8"
225mm = 7.5", 8" and 8.5"
235mm = 8" and 8.5"
245mm = 8", 8.5", and 9"
255mm = 8.5", and 9"
265mm = 8.5" and 9"
275mm = 9" and 9.5"
285mm = 9" and 9.5"
those are safe tire sizes for different wheel widths
Old May 10, 2007 | 09:07 PM
Neothin's Avatar
and i've seen a SUPER stretched 225 width on a 10" wide rim on an rx-7. stupid, VERY hard to get a shop to do it, but doable
Old May 10, 2007 | 09:50 PM
hawgs74's Avatar
Old May 10, 2007 | 11:15 PM
peter_x9's Avatar
I was doing searches on tire sizes earlier. I've made up my mind. Where can I find cheap 255-30-19 tires? Cheapest I found were $250 a piece.
Old May 15, 2007 | 06:47 AM
MPanova's Avatar
I would run a 255-30 up front and 275-30 out back
http://www.tirerack.com/tires/tires....e1=yes&place=0
http://www.tirerack.com/tires/tires....1=yes&place=13
Old May 15, 2007 | 12:31 PM
nebster's Avatar
naw you can get away with a 255 out back.
Old May 16, 2007 | 02:09 AM
MPanova's Avatar
If you run a 255 on a 8.5 front its going to look perfect, if you run that same 255 out back on a 9.5 its going to be stretched and the side wall is going to lean in and the edge of the tire is not going to touch the edge of the wheel and since the front is perfect its going to make the back look even more like a bucket of _______s
Old May 16, 2007 | 02:16 AM
nebster's Avatar
ummm i have a 255 on a 10 wide and it doesn't look stretched at all. trust me a 255 on a 9.5 will be fine.
Old May 16, 2007 | 02:20 AM
MPanova's Avatar
I would like to see that
Old May 16, 2007 | 02:31 AM
Jiggaman's Avatar
Big Sky Scion
i would LOVE to see pics of that!!!
Old May 20, 2007 | 12:49 AM
2_much_tc's Avatar
i have a staggered setup. 19x8.5 front on 215/35 and 19x9.5 rear on 225/35's. its the stretched look, but i think it looks really good.
Old May 20, 2007 | 06:53 PM
hawgs74's Avatar
Got any pics?? U running a wide-body or what?
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
ploniaczysko
Jan 28, 2015 02:15 PM
