Accessory fuse acting up, what do i do.
Every time i hit a bump my accessory fuse goes on and off, as in my radio goes off and then on, and other things that run off it go on and off. I have put in new fuses and it still does it, It is not making a good connection, i am going crazy, i hope the wire on the back of the fuse panel isn't loose or something.
i would check behind the fuse block then to make sure all of your connections are secure. proces of elimination is usually the easiest way to fix electrical. what else do you have running off of it?
They are all good i checked them it is that i can push on the fuse and it will work and then not work, and if i hit a bump it will do it too, i don't know. gonna check the back of fuse panel asap. i will update when i figure it out.
