Passenger window wont roll down
Old May 21, 2007 | 09:39 PM
nebster's Avatar
Default Passenger window wont roll down
Ok i know this comes up a ton bc people disconnect their battery blah blah.
i've done it a million times and i know how to reset the windows BUT this time my pass window wont roll down at all.
does anyone know where the fuse is for that motor? i dunno what else it would be i checked the plug on the harness and thats good, i held it for 5 second in both directions and that didnt work so i dunno.
either way what fuse is it on so i can at least see if the fuse has gone bad.
doubt after 20k miles the motor is damaged.
Old May 21, 2007 | 09:46 PM
tCb00b's Avatar
Did you see if the lock out switch was accidentally pressed down. Its the square one with the red ring around it on the driverside door panel with the rest of the switches. Sometimes it gets activated and that will lock out the window on both sides. Are the LED's in the window switches green? blinking or solid?
Old May 21, 2007 | 09:59 PM
Cabana's Avatar
Mine took a day to work after disconnecting the battery, maybe try waiting?
Old May 21, 2007 | 10:09 PM
nebster's Avatar
____ing child lock. yep that was it. lol i r noob
Old May 21, 2007 | 10:16 PM
Daskid's Avatar
This happened to me too. I almost freaked out. Damn that button!!!!!!
Old May 21, 2007 | 10:28 PM
KINGxOFxSKA's Avatar
Unique Scionikz
Old May 21, 2007 | 10:32 PM
nebster's Avatar
*bows*
thank you thank you
i know am going to fiberglass over that button so i never press it again with my fat ___ arms
Old May 21, 2007 | 11:03 PM
SquallLHeart's Avatar
door lock button pwns you..
case solved.
lockity lock
x2x3
Aug 4, 2015 09:07 AM
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
x2x3
Jul 12, 2015 12:28 AM
