Passenger window wont roll down
Ok i know this comes up a ton bc people disconnect their battery blah blah.
i've done it a million times and i know how to reset the windows BUT this time my pass window wont roll down at all.
does anyone know where the fuse is for that motor? i dunno what else it would be i checked the plug on the harness and thats good, i held it for 5 second in both directions and that didnt work so i dunno.
either way what fuse is it on so i can at least see if the fuse has gone bad.
doubt after 20k miles the motor is damaged.
Did you see if the lock out switch was accidentally pressed down. Its the square one with the red ring around it on the driverside door panel with the rest of the switches. Sometimes it gets activated and that will lock out the window on both sides. Are the LED's in the window switches green? blinking or solid?
