Interior Lights installation help
Old May 22, 2007 | 02:51 PM
AndyTC's Avatar
Default Interior Lights installation help
I have just bought some interior lights, they are lazer blue LEDs
can't wait to install, i have 3 in a little plastic square
so i have two for each side + 6 LEDS.
they have no installation instruction because they are pc lights hahaha but they are stronger than normal LEDs and cheaper
Please send me some pictures of how youguys installed yours !
and some written advice and ideas, I have yet to by the stroggle switches with LED in them and the wiring
so tell me what to buy as to wiring any needed fuses or fuse boxes ?
I would greatly appreciate that ! Im in michigan
I will be proceedng with project this friday, so please reply quick
Old May 22, 2007 | 03:02 PM
oni424's Avatar
You will need several things to do it proper. I went with 14 gauge wire, an add-a fuse, a switch from Lowes. I wired the add a fuse to a 2 foot length of 14 gauge wire. ran the wire to the switch's power in. ran the power wire from the leds to the other post on the switch. found a good metal touching bolt for the ground. plugged in fuses for the add a switch and plugged it in the fuse box. put the switch into the dash and I was done. This was an xb install but it is the same for the tc. about 15 bucks in parts and it is a clean professional looking install.
Old May 22, 2007 | 03:05 PM
oni424's Avatar
You should also get terminal connectors and make sure to have electrical tape readily available. it took me about 10 minutes to install. Most of that was threading wires through the dash for the switch.
Old May 22, 2007 | 03:29 PM
AndyTC's Avatar
yeah ive done fog lights on my tc, so i did put in one switch before , so ill do the same for the lights, Thanks for the wire advice im going to go get that this week
the lights are 12v so i know they will work
now when wiring them to fuse box they will still turn on when i want them right ? not with all other lights
do u have pictures of ur lights from under, i would like to see how u mounted them
because im looking for some mounting advice
thanks
Old May 22, 2007 | 05:37 PM
gizmokat's Avatar
I used the cigarette lighter for a power source for mine. Grounded to a bolt near the bottom left of the dash.
I mounted with double sided 3m tape.
I think some others used zip ties...
Old May 22, 2007 | 07:43 PM
oni424's Avatar
I used the fuse space from my break lights used the add-a-fuse so they have constant power. Can switch them on or off even when the car is off.
clickclickw00t
Feb 18, 2015 08:57 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
tC6M
Nov 26, 2014 06:44 PM
randode
Nov 20, 2003 05:46 PM
sithscripter
9
Sep 26, 2003 05:27 AM
