HO ALT
Old May 24, 2007 | 01:34 PM
Luc1f3r's Avatar
Default HO ALT
How many people are in need of one? im gona try and find a couple different people who make them and see if we can get a GP or a bulk buy discount, so who would be in?
Old May 24, 2007 | 02:14 PM
Amoxaphobic's Avatar
What is a "HO ALT"? Is that like an alternate garden ho?
I guess because I don't know what it is, I don't need one. But I would still like to know what it is.
Old May 24, 2007 | 02:33 PM
Luc1f3r's Avatar
correct, if you dont know you dont need one lol... its a High Output Alternator... for tCs with large stereos or other electronics which require more power then the stock electrical can provide.
Old May 24, 2007 | 07:30 PM
lil_will's Avatar
ScionERA
Count me in!
Old May 25, 2007 | 02:30 AM
Tcguy85's Avatar
maaaayyyyybeeee
Old May 25, 2007 | 01:04 PM
Oh, well I guess it couldn't hurt. I am sure that my SoundStream DaVinci amp is pulling more power than many other amps out there. On top of the computer that I am about to put in. So, I'm watching.
Oh, and for the record, I thought you might be talking about an alternator. But the whole "HO" thing threw me off.... way off. LoL
Old May 25, 2007 | 01:47 PM
nebster's Avatar
depends the amps at idle and the $$$
Old May 25, 2007 | 01:54 PM
Luc1f3r's Avatar
yeah, money well work on, but IMO i would like 150amps at idle and 250ish at speed for less the $500. (the 250amp i had in my suburban was only $300 shipped)
Old May 25, 2007 | 01:57 PM
Nick06tC's Avatar
I would consider it.
And the whole if you dont know what it is, you dont need it, isnt true. I am pretty proficient with cars and have done all my systems, body kit, you name it. But had no clue when i saw HO ALT, what it would be.
Old May 25, 2007 | 02:09 PM
nebster's Avatar
well i was looking at a 200 at idle for 400 so it should be significantly less than that for a GB
Old May 25, 2007 | 02:18 PM
BrEaK_AwaY's Avatar
i was thinking the same. when i drained my first yellow top (currently on my second) i started to look at alts, but then stopped. but would still be intrested.
here is a little note for people with a s/c'er: a high output alt, will take up more room, and might not with with the s/c'er because of the s/c'ers pulley.
Old May 25, 2007 | 02:20 PM
nebster's Avatar
i'd like to get a 200 at idle for 300 but anything is better than the 60 stock tbh. just make the pricepoint worth it
Old May 25, 2007 | 02:26 PM
Luc1f3r's Avatar
why would it be larger? everyone i know has a HO ALT, domestic/import cars/trucks and they are all the same size.... only time ive seen them bigger is my friend who has an alt out of a chevy truck in his civic...
Old May 25, 2007 | 02:28 PM
BrEaK_AwaY's Avatar
every HO alt ive seen are slightly larger than stock because it typically has more coils in the alt, which requires a larger housing. i havent seen one thats the same size besides ones that were remade at a machine shop
Old May 25, 2007 | 02:34 PM
nebster's Avatar
yeah they typically are a bit larger. i'd rather that than them recoiling my stock one. that gets expensive
Old May 25, 2007 | 02:37 PM
jetlounge's Avatar
depending upon the capacity, the form factor can remain the same.
Old May 25, 2007 | 02:39 PM
nebster's Avatar
from waht i've read the tc is hard to keep the same size.
Old May 25, 2007 | 03:25 PM
mbaledge's Avatar
tC squad
Couldn't you just overdrive the alternator pulley? You'd miss mb 1 or 2 hp but if you need a HO ALT(lol), I'm guessing that your system would slow you down more than the pulley. But then again, I could be wrong on both accounts.
Old May 25, 2007 | 03:27 PM
BrEaK_AwaY's Avatar
overdriving the alt with a high load will eventually burn it up, and it will need to be replaced. so its better (IMO) to just get a H.O. alt.
and yes, a heavy system will add into the speed/power factor
Old May 25, 2007 | 03:33 PM
mbaledge's Avatar
tC squad
I figured it would, just as underdriving has it's own adverse effects. However, if your S.C.'d and space is an issue, I'd assume o.d. is the way to go, no?
