question on "stock" fog lights
Old May 30, 2007 | 03:28 PM
Luc1f3r's Avatar
Default question on "stock" fog lights
i dont have my gauges in my car at the moment (LED swap) and i noticed today that my ebay factory fogs arent working... i thought they were yesterday(after i pulled the gauges), but i may be wrong.
last night i put in a new led rocker switch(for some neons, not related to the fogs at all other then the switch is in the same switch pannel), wired it up and also installed all new interior lights, now i cant get my stock fogs to light up(their switch also does not light up). Headlights still work, and my 2nd set of fogs still work. (wired strait to the battery, not through the factory harness.)
think i just knocked something loss, but cant figure out what... im at work and its raining so i cant really play with it for another 8 hours. ideas?
Old May 30, 2007 | 03:50 PM
ZlineDavid's Avatar
Check the fuse?
Old May 30, 2007 | 03:58 PM
Luc1f3r's Avatar
good call, always look past the obvious lol. i didnt touch any wire for the fogs other then maybe jiggling them a little when i was hiding the wires for the new switch and the interior neons it controls... but i will check,
what else yall got?
Old May 30, 2007 | 04:08 PM
ScionJim23's Avatar
yea, its most likely the fuse. If you didnt disconnect at least the negative terminal to your battery while installing the switch for you other lights, you may have accidently touched and shorted a wire to you Fogs and cause the fuse to blow since the Fogs have constant power supply to them. This is very common. it happens all the time on accident when wiring new electronics in the car. You may have accidently touched a Fog light power wire and shorted it or possibly knocked the wire lose to the power supply. Check where the Power is ran to the Fogs. Is it connected to you battery or near your fuse panel inside? Check that also. May have jarred it lose on accident when you removed the panel.
Old May 30, 2007 | 04:16 PM
Luc1f3r's Avatar
your a gifted genius my friend! i grounded the switch to the same point where i grounded my fog switch... thats it! you really are godly... who says you cant diagnose problems over the internet! thank you!!!!!!!!!!!!
Old May 30, 2007 | 06:47 PM
ScionJim23's Avatar
So I take it you fixed your problem you were having? Well if ya did, good work. We're here for this kinda of problem solving anytime. Later man
Old May 30, 2007 | 07:13 PM
Luc1f3r's Avatar
no, i havent had a chance to play with it. but that has to be exactly what it is. theres 4 or 5 wires grounded at the same spot, so i may have missed it... or i blew the fuse when i re connected it.
thanks again.
Old May 30, 2007 | 08:18 PM
ScionJim23's Avatar
OOOO..got ya. yea thats most likely what happened. You made contact with the ground wire that is for the Fogs and since it has constant power going through the + wire, the ground you touched shorted it and blew the fuse. Good luck.
Old May 31, 2007 | 01:54 PM
Luc1f3r's Avatar
yaknow the best part of being a ____ing moron... all your problems are easily solved...
on my way home i stopped at autozone for some simple leds for my center air vent and cup holders... when i was pulling into park (the building had a glass front) i noticed my hibeams were on... turned them off and the fogs came on.
oh, the joy of driving without gauges!
Old May 31, 2007 | 03:53 PM
ScionJim23's Avatar
yea driving without gauges is not good. I could see that being very difficult. Do you still have a problem with them or not?
Old May 31, 2007 | 06:21 PM
SquallLHeart's Avatar
you shouldn't drive without your gauges..
or technically with your high beams on either.... :?
yea.. that'll do it.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
amart
Scion xD Aero & Exterior
Dec 23, 2014 12:06 PM
