FYI LED DIYers
Old Jun 4, 2007 | 03:05 PM
crabbyman's Avatar
OhioScions
Default FYI LED DIYers
I found a website in my travels to help those without mathematical knowledge about the calculations or just wanting to double check their calculations on LED series/parallel circuits.
http://led.linear1.org/led.wiz
Have not got to test it yet myself for accuracy. It looks like this site also has other LED calculators for your use!
to them!
Old Jun 4, 2007 | 04:24 PM
engifineer's Avatar
Personally I would break into more branches and use a larger resistor rather than using 1 ohm limiting resistors in the circuits as their calculator suggests to. For example with 4 3V leds on a 12V circuit, it says to put them all in series and use a 1 ohm resistor. Due to tolerance and the fact that it would create a slightly unpredictable circuit, you would be better off using two branches of 2 leds with 220 - 300 ohm resitors for each.
The calcs look correct, I just dont care for thier design strategy too much. Not that the designs wont work.. I just dont think they are the best designs.
Old Jun 4, 2007 | 04:39 PM
crabbyman's Avatar
OhioScions
True..
I guess I was looking at it for more of an "easy way out" method for calculations and such.
I used to be more informed on the whole electrical side of things. I just got back into electrical system and design again recently. So many of the theories and formulas are new to me and sometimes mix themselves up.
So..for a newer person like me...any little bit helps.
You also have a PM.
hondajt
Dec 14, 2015 12:54 PM
jdmautoimports
Regional - Canada
Sep 24, 2015 04:00 AM
Subaru86
Sep 14, 2015 12:43 PM
SJMiller
Sep 12, 2015 06:33 PM
