2004-2006.5 [NCP61]
Opinions of TRD exhaust
Old Jun 16, 2007 | 05:50 AM
GForce's Avatar
Default Opinions of TRD exhaust
I've pretty much decided on a TRD exhaust for my Xa. If you have one are you happy with it? Does it drone in the car at cruising speed? Can you feel any difference in power?Do you have any sound recordings you can post? Thank You in advance
Old Jun 16, 2007 | 05:51 AM
sunnyflorida's Avatar
good questions. i'd like to know too
Old Jun 16, 2007 | 04:20 PM
jct's Avatar
jct
well i got it, sounds pretty nice the install was easy well besides the hangers were a slight pita to deal with once the stock off off the install went very fast!
i did notice power right away over stock... thats the same with the header too
Old Jun 16, 2007 | 05:08 PM
DriverXa's Avatar
There should be a notice in horsepower. With the TRD u'll retain the lower end as it has the valve inside like the stock unit but flows alot better on the top end. If u want a sound clip check out xateam.com as we have a sound clip thread goin on. dexter_5000 has a clip of one with a Blitz SUS and a header and that clip is what made me decide to go with the TRD. Now I just need some $$ to get it.
Old Jun 16, 2007 | 06:10 PM
zdawg913's Avatar
the TRD is a really nice exhaust for the xA. I was 100% set on a TRD before my sponsorship with Strup went through, so I went with the Strup exhaust instead. I absolutely love the Strup, but the TRD was always on top of my exhaust list.... youll be really happy with the TRD!
Old Jun 16, 2007 | 06:57 PM
robbiej's Avatar
I have the Borla, but was told that they make the TRD, so I'd say go for it. I got the Borla because I found it for less than the TRD.
Old Jun 16, 2007 | 07:11 PM
DriverXa's Avatar
http://scionpartspeople.com/SearchPr...+Sport+Muffler
That's the cheapest I found the TRD Muffler for.
Old Jun 16, 2007 | 07:36 PM
GForce's Avatar
Default Thank You
Thank you everyone for the advice on the TRD thats what I'm going to go with. My mechanic will install it for me. The last time we had the car up on the rack to install suspension parts I took a look at the stock muffler. I did't see any bolt on fittings, I sume it has to be welded on. Is trhis correct? Sorry I'm not very mechanical I just like to drive fast on mountain roads.
Old Jun 16, 2007 | 07:45 PM
DriverXa's Avatar
No welding, just bolt it on. Its a clamp.
Old Jun 16, 2007 | 10:44 PM
cobb's Avatar
Does either effect the fuel economy? I understand the lower back pressure can cause lower mpg.
Old Jun 17, 2007 | 12:28 AM
DriverXa's Avatar
If u keep revin the engine to hear the exhaust it will, lol. Naw just drive the car normally and its suppose to actually increase mpg, very slightly but still an increase. And the TRD has a valve in it to keep the backpressure at lower rpms so ur lowend power doesn't suffer.
Old Jun 18, 2007 | 02:44 AM
cobb's Avatar
If it sounds great, I am sure to rev it. Does it sound nice and throatie or like a ricer with a 5 lb coffee can as an exhaust pipe?
Old Jun 18, 2007 | 04:22 AM
DriverXa's Avatar
The clip I've heard of it the TRD sounded very nice. http://xateam.com/forums/showthread.php?t=510&page=2 That link will take u to page 2 of our exhaust sound clip thread. dexter_5000 has a clip on there with a TRD axleback as well as a Blitz SUS intake and an MMW header (both will make the exhaust sound different). His setup sounds awesome. There's also a soundclip thread on here as well. Search for the TRD axleback and u should find a clip of just a TRD muffler and nothing else on an xb. I'll see if I can locate it. But dexter's is the best clip by far.
Old Jun 18, 2007 | 04:38 AM
DriverXa's Avatar
http://www.andrew.cmu.edu/user/awlin...6/MOV01572.MPG
Here's that other clip I mentioned above.
DJ_FroZone
25
May 30, 2019 07:17 PM
stayintrucha
Mar 17, 2015 08:45 PM
mark13018
Feb 6, 2015 08:57 AM
757_BRDFLY
Jan 9, 2015 12:29 PM
