Creaking and Clunking new springs.
Old Jun 17, 2007 | 02:16 PM
CheapChic's Avatar
Default Creaking and Clunking new springs.
I have all the bolts to factory specs.
I only get it turn slow down grade. normal strait, even bumpy roads just fine.
just turning
anyone
Old Jun 17, 2007 | 06:53 PM
Malibu_Rapper's Avatar
Default Re: Creaking and Clunking new springs.
Are you sure you got the front torsion bar bolts torqued to spec? One of mine was not torqued and it was causing this noise as well.
Other than that, I would think that if the springs are sitting correctly and the bolts are torqued, it should not creak. But I don't have the TRD struts so I cannot say with certainty
Old Jun 24, 2007 | 10:12 PM
roXor_boXor's Avatar
CheapChic did you ever solved your noise in the front?
I was going to start another thread but decided to just add this to yours.
I developed a rattle that sounded exactly like a broken shock on the right rear yesterday. I checked it visually and grabbed and shook everything. nada.
This morning I decided to recheck all the torques on the rear Sway bar install. The lower shock attach bolt tightened almost 1/2 turn and the noise went away.
Thought I would share just in case anyone else developed a similar rattle in the rear.
Old Jun 24, 2007 | 10:24 PM
CheapChic's Avatar
hi
we have an idea where it is comming, it is loud and only happens during take off or slow speed bumps.
95% sure it is not the strut. we did grease all front bushings and check and re-checked all bolts.
we think it is the drivers door hinge area. body flex creak.
it is there where all the noise is.
I will know this week
Old Jul 29, 2007 | 04:48 AM
scvscions's Avatar
I had that problem and it turned out to be the springs rubbing on eachother. There will be signs of this on the powdercoating and you can slience this with that wrap that's on the stock springs.
jthistle
Oct 5, 2015 09:32 PM
Luna7ic
Sep 28, 2015 03:30 PM
BlingSlade
Sep 5, 2015 08:52 AM
AMS13
Aug 20, 2015 07:26 PM
tribe
Jul 25, 2015 05:21 PM
