Need Help... (Piggyback ECU or Standalone)
Old Jun 18, 2007 | 03:07 PM
20tCDude05's Avatar
Default Need Help... (Piggyback ECU or Standalone)
I`m going to boost the tC and I`ve been looking into standalones. My goal is 350WHP. So, do I need internals? If so, does a standalone make it where you don`t need internals? Because I`m on a budget here and don`t wanna build the block, for now anyway. I wanna run 10PSI, is that safe for internals and can the E-Manage Ultimate do that?
Old Jun 18, 2007 | 03:40 PM
Whocares05050's Avatar
Default Re: Need Help... (Piggyback ECU or Standalone)
SEARCH
350 is pushing it on stock internals. 10 psi wont get you there with a piggyback.
standalone > pggyback
one last thing:
DONT BOOST ON A BUDGET
Old Jun 18, 2007 | 03:47 PM
Brett's Avatar
low budget, and high horsepower...
i see a problem already
Old Jun 18, 2007 | 03:57 PM
djafropiq's Avatar
whats that old saying.. cheap, reliable, fast.. pick two..
Old Jun 18, 2007 | 04:04 PM
20tCDude05's Avatar
I was thinking about getting a loan from the bank and that oughta help a lot. I guess I`ll go with a standalone, but at the same time, I sort of think it`s not worth it because I just want 300-325WHP.
Mightygnu's Avatar
haha true that.
honestly it depends what your long term goal is, there is no way your going to squeeze out 350whp and have long engine life. build the block and then boost.
Old Jun 18, 2007 | 04:12 PM
djafropiq's Avatar
ultimate or even blue can handle 10 psi. if you have a budget then i dont think you can get a standalone.. that will run you 2000 ish alone.. i think you can probably build up you motor some with that much money.. also if youre going to be adding to your build over time it might be better to start off with the emanage.. standalone when your finally done.. because i think one cost more to tune then the other and you need to retune everytime you add something.
Old Jun 18, 2007 | 08:38 PM
FIREDOG's Avatar
hydra FTW ..... it will squeeze more power out of that 10 lbs you will be running...
Old Jun 18, 2007 | 08:42 PM
Syldrin's Avatar
Originally Posted by Whocares05050
one last thing:
helllloooooo sig
Old Jun 18, 2007 | 09:08 PM
20tCDude05's Avatar
So, Hydra is better than the AEM?
You think I should get a loan from the bank so I can do internals?
Old Jun 18, 2007 | 09:18 PM
Syldrin's Avatar
i think you should do research on what you're doing. the TC can handle up to 12 psi daily driven. but that is ABSOLUTELY the limit on stock internals. if you build your internals you can throw 30psi at it and it won't care. but you run into the problem all FWD cars have. you will have problems hooking up for traction. it's not just what can my engine handle. you need to get that power to the ground. so if you do that better get some stiff coilovers to help with traction and have fun pricing thoes out. it's been said a countless amout of time and it will be said countless more. it is NOT as simple as putting a turbo kit on your car and you're set.
azepolyn's Avatar
Do you currently owe on your tC already?
Old Jun 18, 2007 | 09:38 PM
20tCDude05's Avatar
Yea, I`m making car payments if that`s what you`re asking.
Old Jun 18, 2007 | 09:44 PM
one last thing:
helllloooooo sig
And this means what to me?
Old Jun 18, 2007 | 09:47 PM
12 PSI is NOT the limit of the stock internals. You have to remember that each turbo puts out different power at different PSI.
Ive been running 14 PSI for 6 months now, stock internals. Boost dosnt usually blow motors, the tune usually does.
Old Jun 18, 2007 | 09:48 PM
Syldrin's Avatar
one last thing:
helllloooooo sig
ment it was funny. and worthy of being put in a sig
I think he is trying to tell you to pay off your car first
Old Jun 18, 2007 | 09:49 PM
one last thing:
helllloooooo sig
I spent like 5 minutes looking at everyones sig scratching my head, saying
" WTF is he talking about sigs for? whos sig? "
haha
Old Jun 18, 2007 | 09:57 PM
20tCDude05's Avatar
If that`s the case, then I wouldn`t be able to boost the tC for 1.75 yrs. :-(
Old Jun 18, 2007 | 10:02 PM
Syldrin's Avatar
no one said anythign about not boosting it
