Need Help... (Piggyback ECU or Standalone)
I`m going to boost the tC and I`ve been looking into standalones. My goal is 350WHP. So, do I need internals? If so, does a standalone make it where you don`t need internals? Because I`m on a budget here and don`t wanna build the block, for now anyway. I wanna run 10PSI, is that safe for internals and can the E-Manage Ultimate do that?
SEARCH
350 is pushing it on stock internals. 10 psi wont get you there with a piggyback.
standalone > pggyback
one last thing:
DONT BOOST ON A BUDGET
i see a problem already
I was thinking about getting a loan from the bank and that oughta help a lot. I guess I`ll go with a standalone, but at the same time, I sort of think it`s not worth it because I just want 300-325WHP.
Originally Posted by djafropiq
whats that old saying.. cheap, reliable, fast.. pick two..
honestly it depends what your long term goal is, there is no way your going to squeeze out 350whp and have long engine life. build the block and then boost.
i think you should do research on what you're doing. the TC can handle up to 12 psi daily driven. but that is ABSOLUTELY the limit on stock internals. if you build your internals you can throw 30psi at it and it won't care. but you run into the problem all FWD cars have. you will have problems hooking up for traction. it's not just what can my engine handle. you need to get that power to the ground. so if you do that better get some stiff coilovers to help with traction and have fun pricing thoes out. it's been said a countless amout of time and it will be said countless more. it is NOT as simple as putting a turbo kit on your car and you're set.
Originally Posted by Syldrin
Originally Posted by Whocares05050
one last thing:
helllloooooo sig
Ive been running 14 PSI for 6 months now, stock internals. Boost dosnt usually blow motors, the tune usually does.
one last thing:
helllloooooo sig
Originally Posted by azepolyn
Do you currently owe on your tC already?
one last thing:
helllloooooo sig
I spent like 5 minutes looking at everyones sig scratching my head, saying
" WTF is he talking about sigs for? whos sig? "
haha
