tC Brake Discs turning Orange..
Has anyone else brake disc's started to turn like an Orange color? I have no idea what it is and it's only on the 2 wheels on the same side of my car. I don't know if its getting rusted or what?
I live in FL and as most of you know we've gone through a few hurricanes and its rained like almost everyday. I don't know if this was the cause. How can I fix this? What is it?
Thanks
__________________
Thanks
__________________
Originally Posted by Blackforge
oxidation(rust)... Its very typical for disc brakes. It happens in less amounts in zinc coated rotors, etc. I wouldn't worry about it.
there's nothing i can do about it? and why is it only on one side of the car?
this is my guess...though u forgot to mention what side it was on...im ganna guess its on the right side?...maybe the mass amount of water running down the curb just abused ur right side of the wheel and rotor...just a guess....good luck with that though....
peace
peace
Originally Posted by LiquidSilver
Drive around and mash on the brakes for a little, that should get rid of it if it's on the disc area.
peace
peace
Originally Posted by Chris R
just drive around.. it will go away when you use the breaks.
C
C
The perimeter?
That's probably the part that the calipers don't touch during breaking, just take off the wheel and used a fine grit sand paper and sand it down.... or paint the outside part of the disc any color you want (i'd assume black to match your car) Don't worry about it not being even, once it dries and you use your brakes, the brakes will rub off the rest and leave a cool paint ring around your brakes :D
LOL; this must be your first car.
As others have suggested, it is just normal rust and is unavoidable.
The rust on your discs will be removed when you drive, from the friction of the brake pads.
The calipers however will be almost impossible to keep clean from rust and brake dust. Every so often you can repaint them (the coats will NOT last long) or have them anodized. If you are really conscience about them, you can try to clean them frequently.
But the "orange" will show up again whenever the discs get wet (rain, car wash, etc).
