installing a boost gauge on the trd s/c
Old Jul 2, 2007 | 03:33 AM
tc-guy's Avatar
Default installing a boost gauge on the trd s/c
i searched and came up with nothing. i was wondering where would a good location be to tap into the vacuum lines at. i looked earlier and there is a small vacuum line that is connected to the throttle body. it already has a t-tap installed on it. my question is that would it work for the boost gauge if i just find a tap that is 4 sided instead of 3(basically like a cross) and hook up the gauge thru that, would it work? any help is appreciated.
Old Jul 2, 2007 | 03:38 AM
06SuperWhite_SoCal_tC's Avatar
vacume line from the BPV works perfect for me. Then for power tap it into the fog light plug behind the dash, and ground the other wire.
Old Jul 2, 2007 | 03:53 AM
tc-guy's Avatar
thanks for the response. are u talking about the fat tubes connected to the bpv? because most gauges comes with the little tubes only.
Old Jul 2, 2007 | 04:43 AM
it should be the tube directly connected to the BPV. Follow it to about the center of the tube, cut it in half and put a T reconnect the vacume tubes together, then insert the Line from the boost gauge through the firewall gromet into the T fitting. Ill take pics for you real quick, from the motor side.
Old Jul 2, 2007 | 04:47 AM
Should look like this brass T fitting that came with my TRD gauge.
Old Jul 2, 2007 | 05:00 AM
tc-guy's Avatar
thanks very much for all your help.
Old Jul 2, 2007 | 05:34 AM
No Prob Man. Besides thats what were all on here for riiight???
Old Jul 2, 2007 | 05:39 AM
tc-guy's Avatar
hey one more question for u. are our oxygen sensors narrow or wide band and whats the difference. the a/f gauge is for narrow band only. sorry but im a noob at gauge installs.
my06tc
Jun 25, 2015 12:18 AM
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
