installing a boost gauge on the trd s/c
i searched and came up with nothing. i was wondering where would a good location be to tap into the vacuum lines at. i looked earlier and there is a small vacuum line that is connected to the throttle body. it already has a t-tap installed on it. my question is that would it work for the boost gauge if i just find a tap that is 4 sided instead of 3(basically like a cross) and hook up the gauge thru that, would it work? any help is appreciated.
it should be the tube directly connected to the BPV. Follow it to about the center of the tube, cut it in half and put a T reconnect the vacume tubes together, then insert the Line from the boost gauge through the firewall gromet into the T fitting. Ill take pics for you real quick, from the motor side.
my06tc
Jun 25, 2015 12:18 AM
anti_virus347
May 28, 2015 06:01 AM
anti_virus347
Apr 3, 2015 05:17 PM
mattjk
121
Dec 22, 2004 10:49 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
