clink clink, whats that sound?
Old Jul 7, 2007 | 02:43 AM
Luc1f3r's Avatar
Default clink clink, whats that sound?
i have hotchkis front and rear sway bars. (not sure if they are the cause but they are there...)
never noticed the sound until about 2 weeks after i had the front and rear sway bars installed...
from the rear of the car, when i go over big bumps, big dips, speed bumps, and some times in turns, i will hear a clink sound, not quite a metal on metal sound, but more then a plastic on metal sound...
i can hear it in my car, i have had friends in my car who could hear it, i had one of them pace me and when i would hear the sound they wouldnt hear anything, so i dont know if it can be heard outside or not..
where should i start looking for issues? it sounds like its more on the drivers side, but some times it will seem like its coming from the passengers side... it almost sounds like my exhaust is jumping in the hangers, but i have magnaflow cat back, and its welded to the hangers, so it cant be that...
ideas?
Old Jul 7, 2007 | 02:44 AM
Luc1f3r's Avatar
oh, and i had the sway bars installed on their stiffest settings also also, no drop springs, on 19" rims...
Old Jul 7, 2007 | 02:49 AM
draxcaliber's Avatar
bad sway bar bushing?
Old Jul 7, 2007 | 03:04 AM
KINGxOFxSKA's Avatar
Unique Scionikz
is it almost like a creaking clink sound?
i had that sort of sound as well. it came from the rear sway bar.
check the bar where the bushing mounts are... mine was not centered properly and was hitting metal. just unbolt it, adjust and re-tighten.
Old Jul 7, 2007 | 03:41 AM
Luc1f3r's Avatar
thats it!
recenter the bar or just the bushing mounts? sorry i paid a shop to install them but would rather fix them on my own... so i dont really know where to start...
jack the car, undo the 4 bolts (2 on each bushing, right? ) recenter, done?
Old Jul 7, 2007 | 04:51 AM
Whocares05050's Avatar
are you sure they greased the zirk ( spelling? ) fitings?
Old Jul 7, 2007 | 05:44 AM
Unique Scionikz
thats it!
yup. just jack up the rear of the car (or drive onto 2x4's). see if the bar is hitting the metal where the bushings are installed. if it is on either side, undo the 4 bolts, reposition it and re-install. you should be golden after that.
hope that helps
Old Jul 8, 2007 | 03:32 PM
Unique Scionikz
So... did it work?
Old Jul 8, 2007 | 04:43 PM
Luc1f3r's Avatar
i got under it yesterday and didnt see anywhere where it could have been hitting so i didnt go any further... i am going to jack it up today... is it hitting at the lows or the highs of the travel? i only checked the highs and didnt see anything...
Old Jul 8, 2007 | 04:47 PM
nytlemgr's Avatar
Do happen to have springs as well?
Old Jul 9, 2007 | 12:42 AM
Luc1f3r's Avatar
no, imma order stechs this week, and i have read those issues, but this is not that, yet.
thanks though.
Old Jul 9, 2007 | 05:31 PM
Luc1f3r's Avatar
ok, shop is done, they said my sway bar was a little lose and they blamed it on the stock end links used with the hotchkis sway kit... they said if im going to lower it (which i am, on S Techs) then i almost HAVE to get new end links... where can i get those? they arent the same thing as a camber kit?
Old Jul 10, 2007 | 07:25 PM
Unique Scionikz
The stock end links hold up just fine, I wouldn't worry. If you are THAT concerned, Progress provides new end links with their sway bar, maybe you can email em about purchasing just those.
Old Jul 10, 2007 | 08:31 PM
Luc1f3r's Avatar
hmm, if they hold up fine with the drop also then its no issue... they guy said teh drop will put the links at even more of an angle... but its possible they just didnt get it tightened all the way the first time...i put about 200 miles on my car before the sound, so maybe they just needed to be retorqued.
thanks!
AMS13
Aug 28, 2015 07:05 PM
6885BLM8435
Aug 19, 2015 03:08 PM
excessads
Aug 19, 2015 02:37 PM
Suburban
Aug 17, 2015 01:22 AM
iFangy
Aug 13, 2015 05:10 AM
