Getting Shocked
Old Oct 5, 2004 | 12:13 AM
exposed29's Avatar
Default Getting Shocked
Is anyone else expierencing this.... most times when I get out of my tc I get a shock as I touch the door to close it. I assume the static charge is either from the seat or the carpet. I wonder if antistatic spray would help.
Old Oct 5, 2004 | 12:17 AM
addie's Avatar
Is this your first time in a car?
Cybergypsy's Avatar
It happend to me all the time in my XA, after 2 months it stopped....maybe the new carpet....it was so crazy, i hated getting out......Static!
Never had it happen in any other car of mine....just the scion!
Old Oct 5, 2004 | 12:28 AM
jlaznlover's Avatar
it happened everytime i used to get out of my civic. it was very annoying. ever since i got the tc. i have nevered been shocked. because i have the factory floor mats with the carpet lining removed so im not exactly rubbing on carpet
Old Oct 5, 2004 | 12:29 AM
mikochu's Avatar
It's Japan's way of slowly doing away with the American people. You should get your sperm checked...
lol, just kidding. It's your clothes creating static with the fabric in the car. I don't think the colder weather helps, either. Do you use fabric softener sheets when you dry your clothes? That may help. Also, try installing a ground wire kit. Some people say it helps to minimize the static shock. I use fabric softener sheets (Bounce) when I dry my clothes and I have a ground wire kit. I don't think I've been shocked by static...at least not in my car.
Old Oct 5, 2004 | 03:30 AM
Lenalove's Avatar
Default ...
ok.. first of all.. how much does it hurt to be shocked?
i mean.. come on...
i never have experience any of that since all the cars ive been on/drove was leather
Old Oct 5, 2004 | 03:33 AM
DuMa's Avatar
its good for your 'swimmers'
Old Oct 5, 2004 | 03:42 AM
unlimited77's Avatar
haha u guys are funny..yea i always get a small shock during the winter from the fabric but if you touch th car like the outside of the car while getting out it would stop you from geting shocked.
my little trick...its like the beat the car at its own game!
Old Oct 5, 2004 | 03:51 AM
projxB's Avatar
it'll go away.. its the newbie process. you're going through the initiation process. hang in there kido
Old Oct 5, 2004 | 05:09 AM
Kyrono's Avatar
Maybe it’s from wearing women’s underwear?
Old Oct 5, 2004 | 05:33 AM
PandaIst's Avatar
Hahaha..that's funny. I also did get shocked for like first 5 months of owning my xA. I got use to the shock that it actually felt good...hahaha ..siikkkeee. It's gone for good now.
Old Oct 5, 2004 | 07:46 AM
wolfgang7's Avatar
i hate static shock.....course it doesn't really hurt but it is annoying....
a trick i use is to open the door and get out without touching any metal, then touch the key to an inconspicuous metal area on the car (as over time it will make marks) while holding the metal part of the key. the shock will be between the tip of the key and the car and will discharge the shock and then you can grab the door and close 'er up.
sounds like a big process when it's all spelled out like that but it's just get out, touch and close.
..............i really hate getting shocked :?
Old Oct 5, 2004 | 08:06 AM
neneago's Avatar
Go to your local radio shack and buy a real small electrolytic capacitor. Touch the tips before you get out of the car. Should discharge you with no pain.
Old Oct 5, 2004 | 09:16 AM
mrtc's Avatar
Just be glad you're discharging the static on the car and not on a gas pump handle:
http://www.cnn.com/2002/US/12/05/gas.pump.fires/
Old Oct 5, 2004 | 02:01 PM
Kyrono's Avatar
I saw a story on this it is pretty bad about the gas pump issue. Intresting enough how people get in and out of the car while they are pumping gas, it showed women do that the most by behavior the brief study on the show Mythbusters mostly trying to prove Cell phones are whats not responsible for starting the fires, but instead you moving in at out while the pumps going.
Old Oct 5, 2004 | 02:24 PM
mikochu's Avatar
The way I was told to prevent static shock is to touch the metal door frame while still in the car, so it'll ground you before you get out of the car.
What about shocks when I get out of my car?
Many people experience shocks when they get out of their car. Often they believe that the car is charged - but this is not normally so.
Sitting in the car, electrostatic charges are generated on the car seat and the person's body, due to contact and movement between the clothes and the seat. When the person leaves the seat, They take half of this charge with them. As they get out of the vehicle, their body voltages rises due to this charge - a voltage of 10,000 Volts is not unusual.
When they reach to touch the vehicle door, the electrostatic discharge and shock occurs as their hand approaches the metal door.
The voltage build-up can often be avoided by holding onto a metal part of the door frame as you leave the seat. This provides a return dissipation path for the charge on your body.
If you have forgotten to hold the metal door part as you leave the seat, a shock may often still be avoided by touching the glass window before you touch the metal door. The glass may be conductive enough to dissipate charge, whilst preventing the rapid discharge which is felt as a shock.
Old Oct 5, 2004 | 02:43 PM
dulcimoo's Avatar
Default Ha Ha Ha
Now ... get a tesla coil ... somthing 250,000 volts ... now THAT was a shock (6 FOOT sparks) Used to give demos with the thing.
Old Oct 5, 2004 | 02:46 PM
mikochu's Avatar
Default Re: Ha Ha Ha
Then, get a flourescent bulb and use it as a light saber!
Old Oct 5, 2004 | 04:03 PM
TrafficinLA's Avatar
Tesla coil alarm system.... :twisted:
Old Oct 5, 2004 | 04:24 PM
dulcimoo's Avatar
Default Zoot
Yeppers! But put it in plastic so if you hit somthing you will not get hurt.
BlingSlade
Oct 19, 2016 12:39 AM
jthistle
10
May 9, 2016 09:48 PM
babyfac3pn01
Oct 19, 2015 07:24 AM
Darrenohooligan
Sep 26, 2015 07:21 AM
user9430961
Sep 24, 2015 01:09 PM
