swapping hoods question! help
Old Jul 25, 2007 | 05:47 PM
DEEMO's Avatar
Default swapping hoods question! help
im trying to swap out my stock hood to a cf hood and was wondering if its difficult to do or not. I am a newbie at this so if anyone has a step by step tutorial or if i should take it to a professional
Old Jul 25, 2007 | 06:01 PM
Tecrun19's Avatar
Its easy 4 bolts hold the hood down, 2 on each side. You just need a second person to help hold up one side while you take the bolts out.
Old Jul 26, 2007 | 12:05 AM
Importspeed's Avatar
and the part in the front where the hood latches into undo some bolts there and slide it up as far as you can. this is so that your hood will lock into place, i switched my hood for a seibon cf oem hood and had problems with it latching asked around and then asked the company and that is what they told me other then that just make sure it is lined up and no big gaps, if you would like to see mine go check it out on my myspace page or http://www.cardomain.com/ride/2662369 later and good luck
Old Jul 26, 2007 | 02:47 AM
giftednimrod's Avatar
yeah, just get a solid wrench and 1-2 other people to hold it and you are golden. Make sure you disconnect the washer fluid line too before you pop the hood off, thats really simple too, just pull the piping off of one of the connectors under the hood.. when you see it youll know what im talkin about.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
