Best Place to Run Amp Wire
Old Jul 28, 2007 | 07:41 PM
Socalrider's Avatar
Default Best Place to Run Amp Wire
Can someone tell me where is the best place to run a AMP Power wire thru the fire wall, I have been looking on the R/H side where the Main harness goes into fire wall, there is a big rubber plug there and there looks like there is two nipples that could be cut to pass a wire thru there, has anybody used this to pass there AMP wire thru.
Thanks,
Erik
Old Jul 29, 2007 | 01:29 AM
Harleyguy's Avatar
either side is fine, but be patient! I ran mine through the drivers side because of my set up. take your time and it will work out.
Make sure you go through the grommett (or rubber boot) and then seal up the hole with silicon sealant.
Old Jul 29, 2007 | 01:31 AM
TerribleTed's Avatar
The right side can be used but access from the inside to pull the wire on thru is annoying (I ran alarm and engine bay lighting thru these. The main harness rubber boot in front of the driver is the best choice I think to run in amp wires. The boot is big, a small slit can be made and very large wire run thru with very little trouble. Access from the inside is good. The wire run may be shorter (depends on where amp is located) and you also do not need to string as much wire in the engine bay between the battery and the firewall. After the wire is run seal around it with a dab of clear silicon sealer as a leak precaution (do this on either side). My car and many others mount their main power wire fuse (make sure to get a waterprooof one) using the unused welded nut on the strut tower about 4 inches behind the battery, making for a clean secure installation. If you carefully cut away a little of the red plastic positive post cover to clear your new amp wire you can close the cover again after you are done and the install from there to mounted fuse and on into the drivers side harness boot looks like a factory level install
Old Jul 29, 2007 | 01:48 AM
Harleyguy's Avatar
Terrible Ted is right on. I found some pics when I was running my power wire. Please note i did seal the wire up after i took the pic. Hope it helps.
And yes, I did screw the fuse block to the top of the fuse box. I cut the screws short and made sure that they would not hit anything. looks great and factory looking.
Old Jul 29, 2007 | 02:15 AM
Socalrider's Avatar
TT/Harley Guy,
You guys Rock, thanks a bunch, i really didint want to try and drill a hole and cause major problems. Those Pictures are exactly what i need to see.
Thanks Again!!
Erik
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
randode
44
Jun 29, 2004 04:19 PM
Docofmind
Oct 25, 2003 04:33 AM
vpkb
12
Oct 8, 2003 04:17 AM
