Harness for 2007 TC Pioneer HU with IPOD
Old Jul 29, 2007 | 02:28 PM
socalsciontc's Avatar
Default Harness for 2007 TC Pioneer HU with IPOD
Ok I am either going to install the Pioneer IPOD HU into another vehicle or sell it. I have the HU, the short harness that taps into the car harness and the Ipod Cable itself. If I am going to install into another car I need the harness piece that goes from the HU and stops right after they shifter... (this is where you plug in the short harness).
So is it possible to get this harness? I looked at just removing just that part but it goes into a larger part of the harness and is then mixed in with other wiring. I doubt that it would come out easily.
If anyone has removed that part or knows where to get it please let me know.
Old Jul 30, 2007 | 03:46 AM
mattieg's Avatar
yup all you need is a toyota reverse harness. it will be SCOSCHE TA02RB
Old Jul 30, 2007 | 12:56 PM
billc's Avatar
Default Scion interface cable
There are two type of these interface cables available on ebay "SC12235" and "SC12234".
You can contact the seller if you have any questions.
Old Jul 30, 2007 | 01:26 PM
This one is for connecting the HU to power, speakers, etc.. correct? Its labeled as Toyota Power/4 Speaker Connector. I do actually need this but Im looking for the harness that connects directly to the HU and the other end connects to the short harness that mounts in the armrest compartment and has the IPOD port.
This would definitely work and I might end up being forced to go this route but I was hoping to use the IPOD port harness I have and just fill in the gap between it and the HU.
Thanks for the info...
Old Jul 31, 2007 | 02:04 AM
mattieg's Avatar
hmmm i havnt seen the plug for the ipod jack. You might get better luck calling the dealer. And see which one of the numbers match that Bill posted. Good luck
Old Jul 31, 2007 | 10:51 AM
billc's Avatar
Default Scion harness
The harness that you are looking for is not available from Toyota as it is part of the main harness.
This person on ebay makes two types of cables.
One is for people that already have the other two cables and need the main harness one that plugs into the head unit and connects under the console to the other cable that mounts into the console. This is his part number SC12234
The other cable is for people that have neither of the other cables. This cable connects to the head unit and the other end connects directly to the iPod. This is his part number SC12235.
I know that he has one of the latter listed on ebay now, but you could contact him about the other model.
Old Jul 31, 2007 | 01:18 PM
Thanks... I misread your first post. I sent a message and waiting for the price. Depending on the price of the harness, I may end up attempting to remove that section of harness myself.
Old Aug 1, 2007 | 04:08 AM
Same price for the other harness ($70). Quite a bit more than I want to spend to put a cheap HU into a Buick Lesabre Im going to unwrap that section of the harness and see if I can get that part out. If that fails then Im going to cut both connectors off and wire back to make my own harness.
XB06
15
Oct 1, 2022 10:24 PM
O5_TRD_tC
Feb 18, 2015 09:01 PM
tha17
Feb 5, 2015 12:56 PM
Beesh
Jan 9, 2015 06:30 PM
minter66
Dec 15, 2014 01:45 PM
