Air bag compressor wiring question
Old Aug 4, 2007 | 05:30 PM
bruceb's Avatar
Default Air bag compressor wiring question
I was thinking about using two of the empty slots in my distribution block to power 2 air zenith compresors. it is 0ag from the battery to the distribution block then there are 4 4ag leads going to 4 amps. I am just worried that that all would be to much draw on the 0ag wire and that i will prolly get noise through the speakers when the compressors kick on. Any advise would be great. Thanks
Old Aug 4, 2007 | 07:01 PM
TerribleTed's Avatar
Default Re: Air bag compressor wiring question
I seriously doubt you could draw more current thru 0awg than it can handle even if you hooked up 2 other whole cars thru it...however your noise considerations are possible but I think not likely. I suggest hook it up at the distro block and see. You can always rewire if there are issues.
Old Aug 6, 2007 | 02:18 AM
low_down_xb's Avatar
i want a AZ but are cars just can handle that kinda current draw unless you have a alternator upgrade putting out some serious amperage, i was told that each AZ draws close to 80 amps so two would be 160a plus your amps and lighting and that is one huge draw on the system
Old Aug 6, 2007 | 05:07 AM
The draw on a car might indeed be an issue. He asked about the wire size. The wire is certainly up to the task. The battery and the alternator ....that might be a different story indeed.
Old Aug 6, 2007 | 10:47 AM
bruceb's Avatar
I should be good with that, optima battery and h/o alternator on the way. Thanks for the input.
carid
Jan 22, 2015 12:49 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
TheRedBox
32
Dec 18, 2003 04:25 PM
LinexA
Nov 21, 2003 02:54 PM
