Sub enclosure question
Old Aug 4, 2007 | 11:04 PM
jesterscourt's Avatar
Default Sub enclosure question
I am in the process of building a custom enclosure out of 3/4 mdf. I plan on making a ring for each 10 inch woofer to sit on so I can elevate them from the surface of the box. But I want to blend it. I have seen it done b4 with what looks like bondo. I am just curious if that is the right material to use or is there something else that is better?
Old Aug 5, 2007 | 12:59 AM
nebster's Avatar
you don't want to use bondo you want to use fiberglass to make it uniform.
Old Aug 5, 2007 | 04:28 AM
Are you sure? It seems a bit rediculus to use fiberglass just in that small of a spot we are talking like only and inch at max of area around the rings. I have seen this done b4 Im just not sure what compound they used. It looked very similar to bondo. I believe I saw it done on unique whips and posibly on another show as well. I am quite perficent at wood working and sanding Im sure I could get it pretty uniform. I just want to know if the bondo will hold up to the speaker vibration or if there is something else I should use.
Old Aug 5, 2007 | 04:42 AM
SirPhobos1's Avatar
fiberglass mat is the way to go. first time i tried to make an enclosure i used bondo and fiberglass mesh.. too many inconsistencies and leaks.
Old Aug 5, 2007 | 04:49 AM
hmm. I really didnt want to get involved with fiberglass. If I was gonna do that I would have built the whole box out of it. Where I would be using the bondo would be such a small amount and it wouldnt be in a location that would leak. I think I might just try it out. I am quite sure that I could get it pretty good. Plus any minor inconsistancies will be hidden when I carpet the box. Unless someone knows of another material besides fiberglass and bondo I think Im gonna try. If it doesnt work I can always remake that panel of the box.
Old Aug 5, 2007 | 05:38 AM
rocketgyrl's Avatar
RAGE Gold or even better, Duraglass will work perfect.
Old Aug 5, 2007 | 02:03 PM
where do you purchase these?
Old Aug 5, 2007 | 02:14 PM
MTcX's Avatar
Scionetics
yeah Duraglass is what I was thinking you might want to try and use. It looks like Bondo in a way so that might be what you saw on the TV show
Old Aug 5, 2007 | 04:44 PM
rocketgyrl's Avatar
Automotive paint supply shops usually have these items...
Old Aug 5, 2007 | 10:19 PM
Thanks for all the help you guys. Im gonna get some duraglass. I am like 3/4 of the way done with the enclosure it looks hot. Ill try and post some pics when Im finished.
Old Aug 5, 2007 | 10:50 PM
I have another question as well if anyone can help me with this one. I looked at the suggested cubic feet for the subs im using and built my box within their recomended limit. But what justifies porting a sub. Like is it all prefrence? could I add a port to my setup? My subs cubic feet recomendation was .65 - 1.25, I built my box to .66. Also is there anybody on here who could possibly walk me through how to set this stuff up once im ready to install? Like I wanna tune it right but I am not that knowledgable about that.
Old Aug 6, 2007 | 12:40 AM
nebster's Avatar
if you look at your sub box recommendations the ported boxes always are much larger. just cutting a hole and sticking a port in the box will sound much worse than having it sealed. i would just leave it sealed.
Old Aug 6, 2007 | 02:00 AM
Ok good thats what I figured. I didnt nescasarly want to put one in just was wondering why it is done and if it would make it sound better.
Old Aug 6, 2007 | 02:06 AM
nebster's Avatar
no in fact it would probably make it sound worse because it would be tuned very high.
Old Aug 6, 2007 | 04:01 AM
cool well I didnt put one in and never really planned on it either was just asking about it. Is there anyone out there that can help walk me through how I should wire everything up?
Old Aug 9, 2007 | 03:28 AM
can anyone help me????
Old Aug 9, 2007 | 03:33 AM
lil_will's Avatar
ScionERA
http://mobile.jlaudio.com/support_pages.php?page_id=145
Check it.
Old Aug 9, 2007 | 04:53 AM
combatsteve's Avatar
If you don't know how to wire it up you should just take it to an audio install shop. They will do it faster and most likely a lot better and safer then you would.
If you really want to do it yourself pm me.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
