Sub enclosure question
I am in the process of building a custom enclosure out of 3/4 mdf. I plan on making a ring for each 10 inch woofer to sit on so I can elevate them from the surface of the box. But I want to blend it. I have seen it done b4 with what looks like bondo. I am just curious if that is the right material to use or is there something else that is better?
Are you sure? It seems a bit rediculus to use fiberglass just in that small of a spot we are talking like only and inch at max of area around the rings. I have seen this done b4 Im just not sure what compound they used. It looked very similar to bondo. I believe I saw it done on unique whips and posibly on another show as well. I am quite perficent at wood working and sanding Im sure I could get it pretty uniform. I just want to know if the bondo will hold up to the speaker vibration or if there is something else I should use.
hmm. I really didnt want to get involved with fiberglass. If I was gonna do that I would have built the whole box out of it. Where I would be using the bondo would be such a small amount and it wouldnt be in a location that would leak. I think I might just try it out. I am quite sure that I could get it pretty good. Plus any minor inconsistancies will be hidden when I carpet the box. Unless someone knows of another material besides fiberglass and bondo I think Im gonna try. If it doesnt work I can always remake that panel of the box.
I have another question as well if anyone can help me with this one. I looked at the suggested cubic feet for the subs im using and built my box within their recomended limit. But what justifies porting a sub. Like is it all prefrence? could I add a port to my setup? My subs cubic feet recomendation was .65 - 1.25, I built my box to .66. Also is there anybody on here who could possibly walk me through how to set this stuff up once im ready to install? Like I wanna tune it right but I am not that knowledgable about that.
if you look at your sub box recommendations the ported boxes always are much larger. just cutting a hole and sticking a port in the box will sound much worse than having it sealed. i would just leave it sealed.
bootlgr
Jan 26, 2016 01:22 AM
