Installing HIDs, HELP!
Old Aug 11, 2007 | 05:39 PM
ParadoxTC's Avatar
Default Installing HIDs, HELP!
Alright,
I got my HIDs from 3bspec.com
and I'm trying to install it in but the HID bulb wont lock in.
I got the 9006, 6k ones. I'm trying to lock it in like the stock bulb, where you just push it in and turn it. The HID bulb I tried to put in, won't just push in and lock.
HELP?!?
aim me =(
Old Aug 11, 2007 | 05:49 PM
underoath777's Avatar
um check to make sure they are the right bulb type first.
also look through the front of the headlight to make sure the tabs are in the right spot to push in then turn
Old Aug 12, 2007 | 01:46 AM
emptystreets130's Avatar
I'm having the same problems as you are. Is this just on the driver side? I had to change the o-rings on the bulb to the o-rings that were on the halogen bulb. It's not a tight fit so I'm worry about condensation when fall hits. My passenger will lock but the driver side will only turn a 1/4.
Old Aug 12, 2007 | 09:32 AM
ParadoxTC's Avatar
I found out what was wrong. I put it in the high beams instead of the low beams lol.
3bspec.com rocks! I bought my HIDs from them and I called them and they helped me out SO much =) Overnight shipping also, FTW!
You don't need to change the O rings, are you sure you're doing it for the LOW beams? I took out one O ring and I figure that the stock bulb is smaller than the HID so that's when I found out that I was replacing the wrong bulb lol
hit me on aim if you're still in trouble! =)
Old Aug 15, 2007 | 06:33 PM
JonnyHomesick's Avatar
i had the same issue. I removed the O Rings and then they fit perfectly. I had an issue with a bad bulb/ballast though.
But fitment....yea just take off the O Rings...worked perfect.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
clickclickw00t
Feb 18, 2015 08:57 PM
tc_Jake
Dec 31, 2014 01:45 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
