Question about separating headlight lens
I actually kept as much of the old adhesive on as possible, then baked them again and pushed them back together as much as possible. I then got some clear silicone and ran a bead between the housing and the clear lens
My headlights still haven't fogged up, and its been about 2 months after I baked them open
Well I did like you said and left as much of the original silicone on as I could, I put some clear silicone on top of the original, put the lights back together, baked them for seven minutes, tightened all the screws, and then put some more of the clear silicone on between the housing and lense. So hopefully that does the trick. What a pain in the butt though. Don't really want to have to go through that again!!!
It sounds like you took your time, and did it right, you should be fine
Well I woke up this morning and no condensation, but because of the nice weather, that doesn't mean it worked, but hopefullt it did. But I didn't put any packets in there will it still be ok?
You will see if it worked after you wash your car
Ok where can I get these packets of sicla Gel because my passenger headlight now has a little bit of condensation? Figures and I thought I was in the clear. Here is the thing though I probaly won't be able to get this done for like a week because of my work schedule. Will this do any damage cause I have HID's? I really don't feel like doing this again, but that is ok cause I am going to order some rage halos and just do it all at the same time.
Oh are those though stupid packets that you find when you buy something new? I didn't even realize what they were but now it all makes sense as far as absorbing moisture. Thanks!
I just go to the sporting goods store and unleash fury into all their shoe boxes and come up on like 30 at a time haha. Make sure you put silicone in the crevises where they meet before putting them back together and then back them closed then after put cilicone on the out side. I have done about 20 sets and have had no fogging issues
have fun!
So do I just stick them in anywhere obviously where they won't be seen? And what about the HID's? If I don't get this for a little while will anything get damaged? It is only in one light and it was very minimal.
MobileHIDs has ones that he put the ballast and bulb in water and it was lit fine. Not sure if all are fine with it though.
bootlgr
Jan 26, 2016 01:22 AM
