Question about separating headlight lens
Old Aug 13, 2007 | 09:01 PM
tc1stgen's Avatar
Default Question about separating headlight lens
Before I reassemble, do I have to get all of the original silicone off before I apply the new silicone?
Old Aug 13, 2007 | 10:26 PM
NVMyTc's Avatar
I actually kept as much of the old adhesive on as possible, then baked them again and pushed them back together as much as possible. I then got some clear silicone and ran a bead between the housing and the clear lens
My headlights still haven't fogged up, and its been about 2 months after I baked them open
Old Aug 13, 2007 | 10:33 PM
Viace's Avatar
Leave all the glue on as you can.silicone before you close as well as after
Old Aug 14, 2007 | 01:58 AM
tc1stgen's Avatar
Well I did like you said and left as much of the original silicone on as I could, I put some clear silicone on top of the original, put the lights back together, baked them for seven minutes, tightened all the screws, and then put some more of the clear silicone on between the housing and lense. So hopefully that does the trick. What a pain in the butt though. Don't really want to have to go through that again!!!
Old Aug 14, 2007 | 02:27 AM
Viace's Avatar
Ya its not very fun I should have added that you should always put at least 4 packets of sicla Gel inside just incase.
Old Aug 14, 2007 | 03:00 AM
NVMyTc's Avatar
Tell me about it, the first time I baked them back together, I didn't push them back together very hard or put the bead of silicone between the housing and the lens, and it had condensation the next morning. So I had to do it again, god what a pain!!
It sounds like you took your time, and did it right, you should be fine
Old Aug 14, 2007 | 01:16 PM
tc1stgen's Avatar
Well I woke up this morning and no condensation, but because of the nice weather, that doesn't mean it worked, but hopefullt it did. But I didn't put any packets in there will it still be ok?
Old Aug 14, 2007 | 03:20 PM
NVMyTc's Avatar
I have no packets and im fine
You will see if it worked after you wash your car
Old Aug 14, 2007 | 04:32 PM
tc1stgen's Avatar
Funny you mention that because I just finished cleaning her up! No fog or condensation. So it seems as though I actually did it right.
Old Aug 14, 2007 | 04:37 PM
Viace's Avatar
lets sure hope so because I hated re doing them its such a hassel
Old Aug 15, 2007 | 03:43 PM
tc1stgen's Avatar
Ok where can I get these packets of sicla Gel because my passenger headlight now has a little bit of condensation? Figures and I thought I was in the clear. Here is the thing though I probaly won't be able to get this done for like a week because of my work schedule. Will this do any damage cause I have HID's? I really don't feel like doing this again, but that is ok cause I am going to order some rage halos and just do it all at the same time.
Old Aug 15, 2007 | 03:48 PM
equinox2355's Avatar
check with a shoe store, or you could goto a place like best buy and look at their laptop bags, they have a ton, and some maybe on the shelves under the bags that had fallen out.
Old Aug 15, 2007 | 04:21 PM
tc1stgen's Avatar
Oh are those though stupid packets that you find when you buy something new? I didn't even realize what they were but now it all makes sense as far as absorbing moisture. Thanks!
Old Aug 15, 2007 | 05:21 PM
Viace's Avatar
I just go to the sporting goods store and unleash fury into all their shoe boxes and come up on like 30 at a time haha. Make sure you put silicone in the crevises where they meet before putting them back together and then back them closed then after put cilicone on the out side. I have done about 20 sets and have had no fogging issues
Old Aug 15, 2007 | 05:25 PM
yep thats them, the ones that say "DO NOT EAT" lol
have fun!
Old Aug 15, 2007 | 05:44 PM
tc1stgen's Avatar
So do I just stick them in anywhere obviously where they won't be seen? And what about the HID's? If I don't get this for a little while will anything get damaged? It is only in one light and it was very minimal.
Old Aug 15, 2007 | 06:03 PM
Yes, just anywhere within the housing and that should work.
The HIDs should be fine, depending on the HIDs.
MobileHIDs has ones that he put the ballast and bulb in water and it was lit fine. Not sure if all are fine with it though.
Old Aug 15, 2007 | 06:58 PM
tc1stgen's Avatar
Ok well I have Pilot HID's which were quite expensive so I hope all will be ok cause I have heard that they will work submerged under water as well.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
