Tein S Tech Springs For tC But what Shock or struts?
Old Aug 17, 2007 | 02:36 PM
trinity41556's Avatar
Default Tein S Tech Springs For tC But what Shock or struts?
I know alot of people here have Installed the Tein S Tech Lowering Springs .. I know its a 2" drop but, what do I use for Shocks and Struts? Because If you use the stock shocks and struts They are made for the stock springs and if you put 2" lowering springs on them ,They wont fit correctly? Im guessing if you put the car on a lift with 2" lowering springs, The shocks and struts will extend too far and the 2" lowering springs will have 2" play in them ? What I mean is you can take the spring by hand and move it up and down with nothing in between ? Will the TRD Struts work? Or are they the same as the stock struts just Better materal ?And also Is it a uncomfortable Ride For the Tein S Tech Lowering Springs I mean is it to stiff and if you hit a bump the car hits hard? or too bouncy with the stock struts? Thank you
Old Aug 17, 2007 | 03:03 PM
OleksiyMU's Avatar
OhioScions
check the sticky in the suspension forum, it should answer most of these questions
Old Aug 29, 2007 | 05:22 PM
insanezane's Avatar
i got s-techs on stock shocks and everything is fine...i put my car on my buddies lift and there was no play in them...the front springs fit perfect without compressing it but the rear you have to compress to get them on...so when the shock goes all the way out they are stuck in place...
Old Aug 29, 2007 | 11:25 PM
DoItBig's Avatar
Scion Dynasty
DeepSouth Scions
sIcKsCiOnS
Scion Tuners
i have my s-techs on stock shocks also..works fine
Old Aug 30, 2007 | 02:33 AM
tc913's Avatar
You can be the first to try out Tokico's set of struts/shocks. They just came out last week and the only place I found them was on ebay. I also have contacted Tokico and they verified that they've sent out a batch of them out but I don't know who has the first batch.
Old Aug 31, 2007 | 03:37 AM
robtheqb2003's Avatar
The ride is kinda rough with stechs on stock struts/shocks. Buddy had them on stock struts at first and changed to trd when they blew out. Ride was a thousand times more smooth...
noisy1
10
May 7, 2015 09:28 AM
Delorean2006
Mar 29, 2015 03:43 AM
Delorean2006
Mar 26, 2015 08:35 AM
sciontcguy15912
Mar 21, 2015 03:58 AM
Renike
Mar 1, 2015 10:40 PM
