Free ROTA Slips 16x7 but +45 offset!!!!
Old Aug 24, 2007 | 11:35 PM
KenzokuXB's Avatar
Default Free ROTA Slips 16x7 but +45 offset!!!!
Got a free set from a friend about a year ago. Took them off of his 99 Civic. Basically my question is: Will I be able to run a +45 offset on an XB??? Isn't that kinda high?? I know OTG has a 10mm spacer for the rear so that shouldn't be an issue but what about the fronts??? Will everything clear?? Any help would be appreciated.
Old Aug 25, 2007 | 06:20 AM
SuperMario6582's Avatar
I used to have set of 18s with a +45 offset. The tires where 225/40/18. They would rub at close to full lock. It wasn't too bad.
Old Aug 25, 2007 | 06:59 AM
hawaiiguy's Avatar
front no problem...but the rear tires will not move...tried that on rota 16 x 7 with same offset a few years ago at the rim/tire dealer (who thought it would not be a problem until it was ALL installed on my car).
Old Aug 25, 2007 | 09:25 AM
JasonReynoldsXXX's Avatar
i just bought rims with a 40 of set are they going to work
Old Aug 25, 2007 | 05:09 PM
Steve60's Avatar
They may work but you will need to trim the rear trailing arm supports ( the round pipe that sticks thru the trailing arm ). You can trim down to the weld & a little ( almost 7/16 - 1/2" ).
A 40 should be a bolt on.
Old Aug 27, 2007 | 01:54 AM
KenzokuXB's Avatar
But it will work if I run the OTG 10mm spacers in the rear correct??
Did I read the above post right??? The front will work with a +45 offset??
Old Aug 27, 2007 | 03:44 AM
987KEITH's Avatar
just rock the otg spacers and u should be good.
Old Aug 27, 2007 | 06:37 AM
Steve60's Avatar
The front should be good to go & if you grind the trailing arm the rear the 45s should also. If you want to buy the 10s for the rear that should work too......
Old Aug 27, 2007 | 06:39 AM
i think i ran a 5mm spacer in the rear. i didnt have to grind nothing down.
Old Aug 27, 2007 | 06:44 AM
Steve60's Avatar
5mm even easier. There's way more than 5mm you can remove from the trailing arm if you don't want to buy spacers.
Old Aug 27, 2007 | 06:48 AM
yeah, 5mm spacers are way easier than grinding stuff down. i think i ran 5mm spacers on all four wheels and hardly ever rubbed.
pro710
Dec 27, 2023 03:34 PM
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
airmankevin1
Nov 17, 2015 05:44 AM
xBrelease08
Sep 13, 2015 04:39 PM
