Free ROTA Slips 16x7 but +45 offset!!!!
Got a free set from a friend about a year ago. Took them off of his 99 Civic. Basically my question is: Will I be able to run a +45 offset on an XB??? Isn't that kinda high?? I know OTG has a 10mm spacer for the rear so that shouldn't be an issue but what about the fronts??? Will everything clear?? Any help would be appreciated.
front no problem...but the rear tires will not move...tried that on rota 16 x 7 with same offset a few years ago at the rim/tire dealer (who thought it would not be a problem until it was ALL installed on my car).
They may work but you will need to trim the rear trailing arm supports ( the round pipe that sticks thru the trailing arm ). You can trim down to the weld & a little ( almost 7/16 - 1/2" ).
A 40 should be a bolt on.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
02-29-2016 05:39 AM
airmankevin1
11-17-2015 05:44 AM
