Polishing My Head!!!
Old Aug 27, 2007 | 01:15 AM
iKONA's Avatar
Default Polishing My Head!!!
Ok... Thanks to my friend Tim and his friend I didn't have to pay anything. I got lucky and am thankful!. I got Megan Headers. Man I did notice a good increase in everything, I don't even have a bad rasp problem and I'm not even muffling anything. These are great! Sounds so much more powerful too might Id add.
My only problem is that the stainless steel finish has its share of oxidation or what ever you want to call it.
Would I be risking the finish by really giving it a good rub down with a fine steel wool pad and then using metal polish on it?
Suggestions?
Old Aug 27, 2007 | 03:25 AM
pb4ugoout's Avatar
well that isn't a head first off...it's your exhaust header. i'm not too sure about this one. I've polished stainless before with a product called never dull. I wouldn't use steel wool on it tho. I think that might put scratches in there that you don't want. you aren't going to harm anything by doing it but make sure you clean off whatever you use really really well. If not, it's gonna burn off the first time you drive the car and it may end up tarnishing the pipes more than the oxidation and it may be permanent.
Old Aug 27, 2007 | 03:32 AM
soros151's Avatar
I thought this was about Port and Polish the head of the engine.... :@
Old Aug 27, 2007 | 03:23 PM
Complication's Avatar
/dissapointment
/threadfailure
lolz
Old Aug 27, 2007 | 03:57 PM
Dr_Isotope's Avatar
Flitz.
Old Aug 27, 2007 | 07:19 PM
MileHightC's Avatar
Super Moderator
SuperMod
It'll still turn colors...even after it's polished.
Old Aug 27, 2007 | 07:27 PM
captainlaziness's Avatar
Just Jet-Hot it and get it over with.
Old Aug 27, 2007 | 07:37 PM
SeanstC's Avatar
Old Aug 27, 2007 | 07:41 PM
iKONA's Avatar
Whats Jet-Hot. I know itl still change colors but at shows I want it to be like how it comes brand new. Clean, polished, and a mirror look.
Old Aug 27, 2007 | 07:44 PM
PlayinWithFire's Avatar
http://www.jet-hot.com/
Old Aug 27, 2007 | 07:55 PM
equinox2355's Avatar
Originally Posted by Complication
/dissapointment
/threadfailure
lolz
LULZ, which is a corruption of LOL which stands for Laugh Out Loud
Old Aug 27, 2007 | 08:19 PM
iKONA's Avatar
Kool. Thanks guys. Copper head looks good!
Old Aug 27, 2007 | 08:24 PM
tCb00b's Avatar
Wet sand with soapy water and 2000grit sand paper. And wear gloves and wipe with acetone or rubbing alcohol after installation to remove oil left from fingers etc. And don't let anyone touch the thing once its installed. I have pics from when I cleaned up my header I bought used but I don't know where they are are the moment.
Old Aug 27, 2007 | 08:46 PM
Bozuzu's Avatar
ay on the jet hot. superior thermal goodness. and $$$. if you want it to look sexy fine hook up this:
http://www.jegs.com/webapp/wcs/store...44845_-1_10261
Old Aug 27, 2007 | 09:26 PM
iKONA's Avatar
tCb00b when you find the pics id like to see :D
Old Aug 27, 2007 | 09:40 PM
iKONA's Avatar
Do I have to powder coat my valve cover If I want to paint it with that duplicolor 1500 degree gloss black engine paint? Or do I go about it the same way as painting anything els? Im a Painter and all so its no problem I'm just not sure if I need to have it powder coated.
Old Aug 28, 2007 | 06:52 AM
RodC's Avatar
Originally Posted by tCb00b
Wet sand with soapy water and 2000grit sand paper. And wear gloves and wipe with acetone or rubbing alcohol.
Are you sure it's a good idea to polish your head with 2000 grit sandpaper and wipe it with acetone?
Old Aug 29, 2007 | 03:10 PM
tCb00b's Avatar
I should have mentioned I did that on my used V1 Megan Racing header. Still looking for pics. Sorry for delay.
Old Aug 29, 2007 | 05:06 PM
iKONA's Avatar
No problemo!
yupinmytC
22
Jul 27, 2024 07:08 PM
prescottn
Oct 8, 2015 05:31 PM
olyellr
Sep 28, 2015 10:32 PM
MisterSkiz
Sep 27, 2015 10:25 PM
BlingSlade
Sep 5, 2015 08:52 AM
