tc with a 3 way set up?
Old Aug 27, 2007 | 02:38 PM
blazeplacid's Avatar
Default tc with a 3 way set up?
Well I've thought about it 145 times and I really want to do a 3 way set up.
I understand that speakers placement is very important in a 3 way set up.
I was thinking about puttin the 6 1/2"mid-bass in a kick panel where the big plastic part is at your feet.
Making a bracket for the 4" mid to go into the factory door location and then the tweet where is it now or up on the b pillar
Brands..Ive heard the Focal and really liked it. The CDTs I havent heard but i've owned 3 pairs of CDTs so I know the 3 way set up will be good.
Anyone have a 3 way set up in thier car??Im looking to spend about $5-$700 on speakers only.
thanks
Old Aug 27, 2007 | 04:07 PM
Keeshwah's Avatar
I'll be done mine at the end of the week if all goes well. Do you have a manual or automatic? And will you midbass have a neodymium magnet? The reason I ask is that there isn't a lot of room behind those kick panels unless you plan on moving all the wiring back there and/or having the kick panels take up some floor space.
I'm also going to assume you mean a-pillar? b-pillar is where your seatbelt is.
Here's a pic of a guy's 3-way from DIYMA.
and here's a link to the thread.
Old Aug 27, 2007 | 04:46 PM
you know i meant a pillar =)
Ilike that but I would think he'd want to use grills
Old Aug 27, 2007 | 05:16 PM
Keeshwah's Avatar
As would I. I also highly recommend not putting the tweets in the door (I know it's not you plan but just mentioning it).
Old Aug 27, 2007 | 10:26 PM
rocketgyrl's Avatar
Car audio is all about compromises. Which drivers play the frequencies you need? Where can you mount these drivers? How large (diameter and depth) are they? What amplifier will you use to drive them?
While 3-way systems have their advantages, I've always been of the mindset where less is more. The two way systems are of course easier to design and install, will require less channels of amplification, etc. Three way systems have more cone surface area, and in some vehicles will yield a better soundstage because you're able to place the smaller, more critical midrange driver where it needs to be - the furthest from the listeners. I can't stress enough how important path lengths are - and keeping them as long as possible, and equidistant.
You'll want the bandwidth of lower than 400hz and higher than 4KHz coming from the furthest distance away from you. Midbass drivers need to be as wide apart as possible, because humans hear those frequencies in a slightly different manner.
Keep the speakers as close to each other, and on the same axis, as practical.
Wide dispersion tweeters with smooth off axis response, work great in kickpanels, while narrow dispersion tweeters work better near the A-pillars. You don't want the sound ping-ponging between the glass and dash. Get a dash-mat! You can test it for yourself by placing some towels on the dash, and listening for the image to tighten and become focused.
You'll want a digital signal processor with time alignment, EQ, and xover with slopes to at least 24dB/oct in order to dial in all the speakers and their different path-lengths. It's much more challenging to get a 3 way front stage to sound "right" because of the added pair of drivers...but I wish you luck!
Cheers!
Old Aug 27, 2007 | 10:55 PM
Hyghgynx's Avatar
Man! I was looking for the 3 nekked girls! I keed. I keed.
Old Aug 27, 2007 | 11:23 PM
Washoutx's Avatar
Default Re: tc with a 3 way set up?
thanks
I have Boston Pro 6.5 3-ways in both front and rear of my tC. I used the factory 6.5 location and the factory tweet location. With the 4" it got a bit tricky. I turned the door panel over and removed a 4" circular section of the white plastic that the black mesh material adheres to on the door approximatly where your for arm would be when reasting your hand on the door handle.
I seperated the mesh material from the plastic without cutting it and effectively made a grill out of the mesh with a 4" behind it, worked out nicely without cutting up my door panel or building fiberglass pods that would just get scuffed up from wandering feet.
Mounted my crossovers in the door panel, this is not a good idea however. The crossovers I have are very large and take up a decent amount of space and thus the door panel was a nice location for them. If you can, avoid mounting crossovers in the door panel if they are large. Over time shutting the door over and over will break solder joints loose on the circuit board.
Old Aug 28, 2007 | 12:38 AM
Keeshwah's Avatar
thanks
You have any pics?
Old Aug 28, 2007 | 03:36 AM
Washoutx's Avatar
Originally Posted by Keeshwah
You have any pics?
I did not take any when I did the install, but the door panel looks total factory still. If we arent too busy tomorrow at the shop Ill pulll a panel and take some pics for ya to explain a bit more.
I did a similar install in the rear for the 4" and tweet, they are mounted behind the side panels with the panel cut out from the backside to allow sound travel.
My profile has pics of my sub enclouse, waiting for paint.
Using a Gt-42 4 channel for the 2 component sets
Gt- 28 for the 3 G5 10's
Erager09
Sep 26, 2016 03:11 PM
danielv
Aug 26, 2015 07:14 PM
toyosg
Scion tC 2G ICE & Interior
Jun 1, 2015 08:43 PM
Tavito
May 28, 2015 08:42 PM
Tavito
