2.25" axleback on turbo car, bad?
Old Aug 28, 2007 | 08:29 PM
nychang65's Avatar
Default 2.25" axleback on turbo car, bad?
So I have a stage 0 and a zpi 2.5 s pipe and mid pipe with a tsudo axleback. The fitment on the axleback sucks and it's crazy loud. How bad would it be if I went with something oem fit like the megan or trd, which happen to be 2.25. Would they be quieter and how bad would it hurt my performance? I plan on going up to 8-10 psi and I only want about 250 at the wheels.
Thanks
Old Aug 29, 2007 | 04:38 PM
ViNNiE_NB's Avatar
Well I have the Greddy EVO2 axleback and a 2.25" straight pipe where my resonator used to be and I don't see nothin wrong with it. Sounds really nice too. Eventually I might get 2.5 or 3" all the way through but that's for bigger HP gains. If ur only lookin to get 250WHP then save some cash and just use ur OEM fitment. I'm currently @ 272WHP with 2.25" pipes. And also, I'm sure if ur tuner knows what he's doing, u can EASILY get 250WHP with 8 psi, no need to up it to 10 lbs, that's just more wear on ur engine u don't need.
Old Aug 29, 2007 | 04:48 PM
nychang65's Avatar
Cool. Just making sure. Is there a big diff between running the TRD and the OEM axleback?
Old Aug 29, 2007 | 04:51 PM
draxcaliber's Avatar
you don't want to up the boost on a stage zero without an intercooler and engine management.
anyway, with a turbocharger you want the exhaust to be as unrestrictive as possible because the turbocharger itself is a restriction on the exhaust system.
a really good exhaust with oem fitment is the dezod s-pipe back 2.5 in exhaust, and you can get them with a second sound chamber to quiet it down, and they are very subtle looking.
Old Aug 29, 2007 | 04:52 PM
the difference between trd and oem exhaust is sound that is it.
also, if you increase the boost, you'll need bigger injectors too. or you'll lean out.
Old Aug 29, 2007 | 04:59 PM
ViNNiE_NB's Avatar
I'm not sure but the TRD might have better airflow, otherwise I don't see a reason for them to even sell one...
Old Aug 29, 2007 | 05:19 PM
with the trd exhaust, you get maybe 2 hp, trust me, i have one, it just sounds cool, but is nearly as restrictive as the stock exhaust.
Old Aug 29, 2007 | 05:36 PM
krdshrk's Avatar
You get 2 HP when you're N/A. I have a full catless exhaust (2.5" ZPI Spipe, Midpipe from the Tsudo N1 catback, TRD Axelback). By the time the exhaust gets back to the axelback section there really isn't much backpressure - the main things that cause the backpressure would be the Cats. TRD axelback does flow better than the stock muffler.
Old Aug 29, 2007 | 05:43 PM
ViNNiE_NB's Avatar
Not to thread jack but how do u pass inspection with an S-Pipe? I thought those remove the cats and pretty much screw ur chance of passing an inspection?
Old Aug 29, 2007 | 05:50 PM
nychang65's Avatar
I have a PWR intercooler, so no prob there. And I know it needs to be open, but I just want quiet too.
Old Aug 29, 2007 | 05:51 PM
nychang65's Avatar
Getting 550's and a retune next month.
Old Aug 29, 2007 | 06:24 PM
ViNNiE_NB's Avatar
U don't need 550's if u only want 250WHP, unless in the future u plan on 350+WHP. Otherwise 440's will do just fine. I'm runnin 440's and I'm @ 272WHP
Old Aug 29, 2007 | 07:22 PM
krdshrk's Avatar
The cats aren't in the s-pipe - they're in the header and midpipe.
Old Aug 29, 2007 | 07:39 PM
ViNNiE_NB's Avatar
Damn all this time I didn't change my S-Pipe because I thought it had the cats, are u satisfied with the zpi? Now I'm gonna have to change mine to get some more power...
Sorry for the thread jack!!
Old Aug 29, 2007 | 07:46 PM
krdshrk's Avatar
Yeah but I bought it used - don't feel like dealing with ZPI directly. There's other companies out there with midpipes.
Old Aug 29, 2007 | 08:37 PM
nychang65's Avatar
I like my piping, but I plan on this thing being a daily driver so I had a shop weld in a high flow car and a resonator. I'm getting 550's cause 440's are almost the same price.
Thanks
XirtaXa
24
Jan 14, 2025 03:49 PM
greytc
Jan 12, 2015 09:49 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
TheTripleC
Jan 4, 2015 06:46 PM
tC_Normo
Oct 22, 2003 07:20 PM
