Installing Subs
Old Aug 31, 2007 | 10:26 PM
arb19ftw's Avatar
Default Installing Subs
Hey guys,
Just bought a 2007 scion tc and love it so far except the fact i can't figure out how to remove the headunit to hookup my subs to it. I also tried wiring the battery wire from the battery and couldn't figure out where to pull the wire into the car from. And if anyone knows what wire from the headunit i need to connect the sub connection to, that would be great.
Thanks a lot
Old Aug 31, 2007 | 10:36 PM
808tC's Avatar
Default Re: Installing Subs
Originally Posted by arb19ftw
Hey guys,
Thanks a lot
to remove the HU you need to first put the car in N and pull out the shifter console...then pull out the waterfall...then you can remove the HU by removing the 4 bolts that hold it down..
as for running the wire from the battery.... run it in the rubber grommet located on the passenger side..
as for connecting the subs to the stock HU.... the only way you can do it is if your amp has high level inputs or if you get the inline output converter to connect to the stock HU...
Old Sep 1, 2007 | 12:07 AM
Keeshwah's Avatar
Read
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
missing_image
Feb 7, 2015 07:18 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
