Bug Guts
Old Aug 31, 2007 | 10:42 PM
sml-27's Avatar
Default Bug Guts
I have a problem, I have some baked on bug guts on the front of my car and I cant figure out how to get them off, anyone have the same problem and a good solution how to fix this?
So far a wash and wax hasent worked I even tried to use me fingure nail and still it wont come off.
Old Aug 31, 2007 | 10:57 PM
Whispaz's Avatar
mmmmm, i love it.
try bug and tar remover. spray let it sit for a bit and try to remove the guts
Old Aug 31, 2007 | 11:14 PM
sml-27's Avatar
I will give it a shot BTW I have the same color as you.
Old Sep 1, 2007 | 05:19 AM
MikeMayer's Avatar
I got bug guts all over too.... its mostly coming off.
Damn suicidal buggies.
Old Sep 1, 2007 | 05:34 AM
OldYeller's Avatar
Get some Stoner's bug and tar remover---and some Stoner's Invisible Glass while you are at it--both products work great............
Old Sep 1, 2007 | 07:13 AM
danos_XBox's Avatar
New England bugs are not as tough. I'm staying out of Pa.
Old Sep 1, 2007 | 07:21 PM
rdfxb's Avatar
Invisible Glass? Never seen this stuff whats it actually do?
Old Sep 3, 2007 | 12:19 AM
sml-27's Avatar
Well I tried bug and tar remover and it dident work,I also tried buffing and it dident work, so then I tried a harsher product, brake cleaner, I know its bad on the paint but it always does miricles for me, sad to say it dident work, somehow the bug guts are under the clear coat of the paint and are permanently there, so a word to the wise poeple if you have bug guts that are fresh wipe them off ASAP.
Old Sep 3, 2007 | 12:21 AM
tc-guy's Avatar
kragen sells a bug and tar remover sponge with a mesh on it that is safe for clear coats. it works great at removing bugs.
Old Sep 3, 2007 | 12:30 AM
tkanaz's Avatar
WD-40... it will take anything off. I use it to remove bug guts, old sticker glue. Works for me.
Old Sep 3, 2007 | 12:00 PM
Maytag's Avatar
Stoner's Invisible Glass is the best glass cleaner. It's aerosol, not pump spray. As far as the bug guts, a terry cloth towel drenched in hot water, place it over the bug guts for about 30 seconds to one minute to soften those buggers. Then they should wipe right off.
Old Sep 3, 2007 | 04:04 PM
stevenism's Avatar
You can also try Mcguiar's ScratchX if the stupid dead bug has left some etchings on the paint. Just use a foam pad and rub it. A few passes removed it for me. Be sure to wax it afterwards.
Old Sep 3, 2007 | 08:45 PM
Pojodan's Avatar
Not much bug guts yet, but a bird did crap on mine the first night I had it
Old Sep 3, 2007 | 08:48 PM
tc-guy's Avatar
bird poop is the worst. its almost toxic. that stuff stains.
Old Sep 3, 2007 | 11:28 PM
ExcelRevs's Avatar
I hate th I-5 bugs on your way to LA. Those bugs are nuts.
Old Sep 4, 2007 | 12:42 PM
techgeekwill's Avatar
Bird poop buffs right out with a decent polish.
I started to take some of the bugs off the front of mine, but then I realized we are mid-way into love-bug season.
Old Sep 4, 2007 | 12:46 PM
insaneintenti0n's Avatar
bugs are... bugging me too. just one drive after washing the car and i swear I'll hit like a cicada or something. Every time. Small bugs are ok, it's the one that leave 1" long splatters that ____ me off.
Old Sep 6, 2007 | 01:20 AM
SoldUYourSkyon's Avatar
Here in FL we get junebugs every summer, and their shells are HARD. It sounds like Dirty Harry taking potshots at your windshield. Makes you want to duck and cover and takes forever to come off...
Old Sep 7, 2007 | 12:58 PM
RockBlocker's Avatar
Sounds like the bugs were either really acidic and acted fast or they might have been on there awhile?? In either case if you are unable to feel the bugs on the top of the paint then they are more than likely etched in your paint like an egg would be. I would recommend taking it to a professional detailer to see if they can wetsand the marks out of the paint.
Couple of things that will help with bug guts
Wash regular of course
Keep wax on the front end as much as you can. Helps keep a barrier built up from the bugs and substance you see on the road since the front ened hits everything and has the most prown area for damage
Clear bras help greatly with bugs. Even if it gets marked from a bug it will bleach out and go away ina few weeks.
Products like Stoners and Tarminator are great to use in a pinch.
Brake Cleaner, wd-40 are not. While they seem to be dry on the surface of the paint they can absorb thru the clear coat and flash the paint. That is not good. Flashing makes you paint all dull and look ruined if it happens. Especially with a lot of heat involved. IE hot hoods from engines and of course AZ
Old Sep 7, 2007 | 01:28 PM
midgethearsexb's Avatar
DelMarVa
May I add a clay bar to these suggestions? A clay bar will do the same thing as wet sanding, it's just not as drastic. I recommend a good clay bar at least once every 3-6 months.
