what needed for clarion MAX675VD?
Old Oct 26, 2007 | 05:13 AM
dveglahn's Avatar
Default what needed for clarion MAX675VD?
What will I need to install the clarion MAX675VD?
and where can I get it at?
and I was reading on something about turning something off with the ebrake so I can watch dvds while driving? what is that about?
thanks!
Old Oct 26, 2007 | 05:53 AM
draxcaliber's Avatar
i would guess you need an install kit and some wiring or harnesses maybe. perhaps you can get that from crutchfield, best buy, circuit city etc.
as for the parking brake thingy.
indash dvd players have to connect to the parking brake sensor to detect whether or not the vehicle is parked and therefore not moving because it is ILLEGAL and irresponsible and dangerous to drive while playing with a distracting movie playing on the screen.
but it is very easy to get around that.
Old Oct 26, 2007 | 06:10 AM
dveglahn's Avatar
how do you get around it?
and where can I get the harness and what kit is good to clean up the gaps?
Old Oct 26, 2007 | 12:27 PM
socalsciontc's Avatar
You are going to need to drill the stock metal mounts so that the mounting holes are slightly back from the stock position so the door will close.
I will have to look at the wiring on mine but the shop put a tiny toggle switch in the ashtray. You cycle it once after turning the HU on and its good to go.
Let me know if you have an IPOD. I have great deal on the cable to hook to this HU.
Old Oct 26, 2007 | 01:09 PM
Baine's Avatar
I have the Clarion VRX775VD and it requires that the e-brake(read that as ground wire)
be cycled three times to watch a video. I just mounted a micro switch under the dash that
is (normally closed). I press the button three times and then the video will play. It is
important that the switch be normally closed as it needs to go to ground continuously
after you cycle it.
Old Oct 26, 2007 | 01:20 PM
Three cycles! So you have to press, release, press, release, press, release? That just doesn't sound right. Right now I just switch over then back but after I replace this switch with a momentary switch it will be just press and release.
Old Oct 26, 2007 | 02:40 PM
Baine's Avatar
my old clarion DVD only required a constant ground but the new one is only a few months
old and I tried the constant ground but it did not work. Three quick press and release
seems to do the trick.
Old Oct 26, 2007 | 07:50 PM
dveglahn's Avatar
I was reading around and there is a switch of some sort that is made..looks like a black box. what does that do? and how is that hooked up? was only bout 30 bucks.
also, is there a kit out there to clean up the sides to make it look like a clean fit?
thanks for the help everyone!
debris
Mar 13, 2015 08:15 AM
rancur3p1c
Dec 19, 2014 04:30 PM
cwong1001
Dec 3, 2014 03:30 AM
XB_2
Nov 23, 2014 02:48 PM
SCI_FIRE
Jan 4, 2004 06:45 PM
