"wooshing" sound from the brake pedal ?! = brake b
hiii guys.. when i step on the brake pedal and release it (fast) i hear wooshing sound... i hear it when i step on it fast and release it fast.. sounds like its breathing :D it has almost the same sound like those foot pumps
Originally Posted by soGone
you have an air bubble in your brake lines and need to most likely have your brakes bled
have you been braking hard recently?
Originally Posted by paul34
Actually, wouldn't an air bubble make it all mushy, but little actual braking bite?
Unless the tC brakes are different, air compresses more than the brake fluid, leading to a mushy pedal. It takes more distance to compress the air enough to supply the force necessary to apply the brakes. The only thing that would result in a hard brake pedal is if power isnt going to the braking system, allowing pressure to release each time the pedal is released.
wonderworm
Nov 19, 2023 01:44 AM
Inazuma
20
May 3, 2023 01:58 AM
