Wiring a 2005 tC with Steering Wheel Audio Controls
Old Nov 12, 2007 | 07:15 PM
mybmw530i's Avatar
Default Wiring a 2005 tC with Steering Wheel Audio Controls
FYI-A 2005 can be modified to have both steering wheel audio controls and interface to a Kenwood DDXXXX. I did such an install over the weekend.[/b]
Old Nov 12, 2007 | 07:17 PM
jjp735i's Avatar
Can you wire one up to the 05 factory radio, what parts do you need?
Thanks, jjp
Old Nov 12, 2007 | 07:24 PM
Sieruc06TC's Avatar
how do you wire it up...i used to have mine wired up when i bought the car...but then i hadda take headunit out to get repaired...and it dont work ne more...
Old Nov 12, 2007 | 08:49 PM
cwayne's Avatar
if it's still under warranty take it to the dealer.
if not, www.crutchfield.com
Old Nov 12, 2007 | 09:32 PM
mybmw530i's Avatar
Parts needed:
1. Steering wheel with audio controls (from a 2006 and up)
2. Smaller airbag from 2006 and up (the 2005 airbag has longer extensions
for the 2005 steering wheel)
3. Toyota stereo adapter with mini 12 pin connector
4. PAC convertor that interfaces steering wheel controls to the Kenwood DDX8019 or equivalent.
5. 150 ohm resistor
Old Nov 12, 2007 | 09:42 PM
mybmw530i's Avatar
Also, there are comments on the board that a 2005 does not have the wiring harness for the audio controls. That is true, however, that is not an issue. Scion gives you the ability to "pass" electrical signals through a spiral wire or ring installed on the steering column. What this means is that you can add capability. You now have cruise control and horn wiring passing through this ring. Adding the audio controls is not that hard. It means using the same 12 pin connector that Scion uses, only with additional wiring.
CombatmedicR56
Nov 12, 2020 01:53 AM
fur_pig
Mar 20, 2020 04:28 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
