Engine Torque Damper
Old Nov 13, 2007 | 03:03 AM
svencarlson07's Avatar
Default Engine Torque Damper
Ingalls "Stiffy" Engine Torque Damper ...what does this do?
Old Nov 13, 2007 | 03:23 AM
draxcaliber's Avatar
it limits engine movement under heavy torque loads so that the power being sent to the tires isn't lost to the engine twisting under the hood.
Old Nov 13, 2007 | 03:24 AM
is it worth it to get it
Old Nov 13, 2007 | 03:53 AM
Aroddalobster's Avatar
i've heard complaints about the vibration and the rattling noise it results in, but i also heard that it gets the job done pretty well of keeping the engine still. an alternative for the eng. damper are motor mounts, which i heard only has increased vibration, but i heard the rear motor mount is a complete pita to install.
Old Nov 13, 2007 | 03:54 AM
so its easier to install then motormounts the only downside is vibrations
Old Nov 13, 2007 | 03:58 AM
no, it is easier to install the torque damper.
the front motor mount is easy, but the rear one requires dropping the tranny.
but the big thing is you get more vibration with both the torque damper, and the motor mounts, but you can take off the torque damper really easy when you don't want the vibrating. but the motor mounts...they pretty much ahve to stay in place.
Old Nov 13, 2007 | 04:00 AM
alright so torque damper it is..thx for the help guys
Old Nov 13, 2007 | 04:01 AM
jovan_gonzales's Avatar
Can a torque damper be used on an auto? You think it helps a lot with wheel hop then?
Old Nov 13, 2007 | 04:07 AM
yes, it can be used on an auto.
Old Nov 13, 2007 | 04:14 AM
Hmmm ... think it will help a lot? I know autos aren't normally the choice of performance, but I just wanna know. Thanks, btw.
Old Nov 13, 2007 | 04:50 AM
Tcguy85's Avatar
i have one i no longer want if anybody wants it. it's in perfect shape.
Old Nov 13, 2007 | 04:53 AM
yeah, just not as much as with the manual because the auto doesn't pull as hard when you launch it like a manual does when you dump the clutch.
Old Nov 13, 2007 | 04:55 AM
Aaah, gotcha, thanks!!!
Old Nov 13, 2007 | 07:08 AM
deathbyc4's Avatar
i run both poly mounts and the dampener. lots of vibrations but less wheel hop. I gots too much torque.
Old Nov 13, 2007 | 03:06 PM
HunterGreene's Avatar
The Dampener we are talkign about is the piece that hooks up on the left side of the engine (looking at the engine), next to the strut, correct?
Old Nov 13, 2007 | 03:08 PM
Enrique9876's Avatar
yes sir.
Old Nov 13, 2007 | 03:13 PM
Sweet, i am so getting one. Nothign more nervewracking to me than hearing the engine rock on the mounts at the strip
Old Nov 13, 2007 | 03:17 PM
i have an unused one if you wanna buy one cheap
Old Nov 13, 2007 | 05:22 PM
Whoops, too late, TCguy got me first
Old Nov 13, 2007 | 07:01 PM
EPIDEMIC's Avatar
DOES IT improve performance though????
