tC Auto Transmission Question....
Old Nov 19, 2007 | 02:23 PM
goin2c3's Avatar
Default tC Auto Transmission Question....
Ok so this is a noob question. But I don't know what to think after searching the forum. Can you shift the auto transmission with the "L" "2" and "3". And if you do does it mess it up?
Old Nov 19, 2007 | 03:30 PM
XIEmperorIX's Avatar
I wouldn't recommend driving that way, it can cause premature wear on the transmission. I've done it a few times for sh**s and giggles but its not the best thing for an auto, also can affect your gas mileage. I might shift down into 3 or 2 on a really steep hill and even that I don't do to often cause the car doesn't have that much trouble with hills.
If you wanna drive like a manual then drive a manual lol I like my auto even though its not as quick as the 5spd guys, but when I get that itch to drive a manual I just drive my grandmothers Corolla XRS or go test drive something
Old Nov 19, 2007 | 04:09 PM
dwrojas05's Avatar
it will mess up.
Old Nov 19, 2007 | 05:03 PM
FMTC08's Avatar
Dont Do It.
Old Nov 19, 2007 | 05:14 PM
1slowtc's Avatar
Strictly Scionized
i do it have done it since i bought the car in 05 50,000 miles on it and no trouble also have about 100+ 1/4 mile passes on it still tring to blow it up did upgrade the trans valvebody this summer so when i shift it it shifts faster. it would drag a little or a lot before now it just goes.
Old Nov 19, 2007 | 05:23 PM
RodC's Avatar
I do it from time to time, only when a lower gear is appropriate. Most of the time it's when I am in heavy traffic on the freeway (5-10mph). If I keep it in D then I am constantly on the brake, but if I use 1st or 2nd then I can slow down just by letting off the gas, so no need for braking.
Old Nov 19, 2007 | 07:14 PM
bellefeuille13's Avatar
I only down shift to 3rd sometimes on the highway to pass people. I wouldnt recomend shifting to low unless u have to because of snow or something. But from what they told me at the dealer downshifting to 3rd everyonce and a while wont hurt it.
Old Nov 19, 2007 | 07:21 PM
cwayne's Avatar
I laugh at fools who drive their automatics as if it were a stick. I saw a fool put his car on neutral in a stop light and put it on D when the light turned green. They also do it when they're on a hill. Let the car roll back, put it on D and go. LOL!!!
Old Nov 19, 2007 | 07:26 PM
AcidDrop's Avatar
i do the same instead of flooring it cause that wastes a $h1^ load of gas just flooring it instead of picking up the rpm quicker.
Old Nov 19, 2007 | 07:30 PM
draxcaliber's Avatar
no, your not supposed to shift an automatic like a manual unless it specfically is equiped with a manumatic shift mode. the auto tc isn't
yes, you can occasionally shift for things like engine brakeing, but you aren't supposed to be driving around up and downshifting like you have a manual.
if you want to shift gears, get a manual, if you want to pretend your shifting gears, get a manumatic, and if you odn't want to, leave it in "d".
Old Nov 19, 2007 | 07:31 PM
AcidDrop's Avatar
Default Re: tC Auto Transmission Question....
if you 1/4 your car then don't do it cause our gears are way to slow to shift, i did that and damn gears didn't change even when i moved it to "2" so just leave it in D all the way even though in the streets you feel more tourge but your stressing out the engine.
Old Nov 19, 2007 | 07:49 PM
XPRESSCION's Avatar
I do it once in blue mood... Today, I actually redline the first gear and let the car fly. No major heavy shifting or odd accelration. When I shifted in two and three gears; easy transmission shifting. Then again, I am at 55k miles too.
I wouldn't do it every day or every week....But I'll do it like every other four months; one time only.
Old Nov 19, 2007 | 07:50 PM
cwayne's Avatar
manumatics and autosticks are ___, IMO. if it doesn't have a clutch, it isn't a manual.
pudgy1's Avatar
yeah you shouldnt be doing that with an auto, unless its needed such as going up a steep hill
woah dude your grandma drives an XRS? thats tight haha
Old Nov 19, 2007 | 08:10 PM
cwayne's Avatar
I wonder if she ever uses lift?
Old Nov 19, 2007 | 08:32 PM
Yeah every once and a while ment I did it once a while a go. haha I agree about people being idiots with auto's
a friend of mine in high school ruined his parents brand new car by pretending it was a standard and racing people. lol
Old Nov 19, 2007 | 08:41 PM
1slowtc's Avatar
Strictly Scionized
if i leave my car in d in the 1/4 it will not shift e-mail address me and i will send a vid of it shift my car all the time 6 psi 13.209 1/4 i can take picks of it. and for people that think they no it all ck all you pro drag cars out tell me just how they shift. all these auto haters i don't have the fastest tc but i got one of the fastest auto tc and at the track i go to the 5 speed guys can't touch me.
Old Nov 19, 2007 | 08:50 PM
sddykstr's Avatar
There's a search button, surprisingly...
Old Nov 19, 2007 | 09:05 PM
AcidDrop's Avatar
but don't you shift like that so you can get more boost than leaving it in D?
Old Nov 19, 2007 | 09:33 PM
1slowtc's Avatar
Strictly Scionized
no the engine is going to produce the same amount of boost no matter what i shift that way because the car will not shift out of 1st gear on its own if you leave the car in drive and brake boost on a line then let go of the brake it takes it right to 2nd gear because of loss of traction then causeing a power loss then it shifts back to frist then gets stuck and at that point i say some crappy words and turn a high 14 second run putting the autos in frist gives the driver the control of when it is going to shift yes a stock auto does dragout when you shift but if you ever upgrade the valvebody you will have already mastered the bounce off of the rev limiter to get it to shift right away
