Fuel Pressure Regulator?
Old Nov 19, 2007 | 06:15 PM
KrazyTc's Avatar
Default Fuel Pressure Regulator?
I got a free Fuel pressure regulator from a friend. My question is if i put it on and raised the PSI. Would i gain any power or would the ECU keep the injectors spraying the same amount of fuel?
Old Nov 19, 2007 | 07:44 PM
Blue_TC_Man's Avatar
I wouldn't mess with your fuel pressure with out tuning the car for it. the ecu would over ride it probably, but you would run super rich if you just upped the amount of fuel. And you could possibly max out your injectors fast. As a rule don't add fuel until you need it
Old Nov 21, 2007 | 06:53 PM
Guru's Avatar
Well number one you have a returnless system on your car. So in order to even install it you will need to either modify your rail and add a return line back to the tank or get a new fuel rail and of course also run a return line to the tank. Secondly, adding fuel will only slow your car down most of the time since the stock ECU runs a bit rich as a margin of safety. Now if you are running a Very large turbo and a built motor the regulator may work well for you along with a full fuel system but right now I'd say it's a complete wasteh of money for you. Next time research before you buy.
Old Nov 21, 2007 | 09:26 PM
superemu's Avatar
it seems he got 'em for free.
Old Nov 21, 2007 | 09:49 PM
KrazyTc's Avatar
Thanks for the info. Like i stated before i got it for free. I wouldnt buy anything with knowning more about the item or install it. Hence thats y i ask before i installed it. thanks
gedster314
14
Nov 17, 2018 02:56 PM
brett561tc
Sep 15, 2015 06:33 AM
Garrettthepatwa
Sep 2, 2015 04:40 PM
carid
Scion tC 2G Aero & Exterior
Sep 1, 2015 09:08 PM
boxcar87
Jul 12, 2015 12:16 AM
