Would it be a bad idea to switch from Mobil 1 to Motorcraft?
Old Nov 23, 2007 | 04:54 PM
Zombietime's Avatar
Default Would it be a bad idea to switch from Mobil 1 to Motorcraft?
I'd like to switch oil brands to save a little money and I know motorcraft is a very good synth blend. Should I just stick with the mobil 1 or will I cause any problems by switching?
Old Nov 23, 2007 | 04:56 PM
draxcaliber's Avatar
so long as it is a good quality brand, and the correct weight and viscosity, it shouldn't be a problem.
Old Nov 23, 2007 | 05:06 PM
Garage1217's Avatar
Bad idea, that is shi* oil.
Old Nov 23, 2007 | 07:36 PM
Zombietime's Avatar
It's bad stuff then? My dad uses it in his lincoln ls and my brother used it in his '03 cobra. I thought it'd be somewhat decent. Maybe i'll just stick with mobil 1.
Old Nov 24, 2007 | 01:23 AM
Maytag's Avatar
Motorcraft Synthetic Blend is a VERY good oil, and can be had at a great price at Walmarts. It constantly gets good used oil analyses at bobistheoilguy.com. I would have no hesitation using it if you're looking to go down to a semi-synthetic oil.
Ultimately though, you should do a used oil analysis yourself to see how a particular oil does in your engine.
Hope that helps.
Old Nov 24, 2007 | 01:53 AM
Garage1217's Avatar
He did not mention the synthetic He mentioned just motorcraft oil which is crap. I am also a member of that forum, good info!
Old Nov 25, 2007 | 02:13 AM
Zombietime's Avatar
Well I did mention they synth blend in my original post but it's cool. I just want to go to a less expensive oil if mobil 1 is overkill.
Old Nov 25, 2007 | 12:43 PM
Maytag's Avatar
If synthetic provides someone peace of mind, then so be it.
For the average driver with a 5,000 mile oil change interval, is it overkill? Sure. Will it provide any better protection than a good dino or semi-syn oil? No.
Now, there are exceptions between specific oils, and how they might perform in your particular engine. That is why a used oil analysis by someone like Blackstone Labs isn't necessarily a bad idea.
Apples to apples, you'll be fine with a semi-synthetic oil at reasonable oil change intervals.
My 08 Xb recommends 0W-20 which I haven't found in a non-Synthetic oil yet. So I suppose it's still full-syn for me.
8URAWD
May 2, 2018 02:22 PM
merotty
9
Mar 9, 2015 05:27 AM
SubrinaIsMyCar
Mar 8, 2015 07:53 AM
CPL_Radar
Mar 5, 2015 05:42 AM
ganyon
Dec 9, 2014 07:40 PM
