MDF vs PVC Baffles?
Old Dec 2, 2007 | 01:59 AM
kidwolf908's Avatar
Default MDF vs PVC Baffles?
While most people recommend MDF for baffles, I've seen many times people with MDF baffles having to replace them after only a few months due to weathering deteriorating them, so which baffles do you guys recommend? I am between these baffles (MDF) from elemental designs: http://www.edesignaudio.com/edv2/pro...products_id=76
and these baffles (PVC) from http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=014
Will the PVC lessen my SQ or cause any unwanted anything? Thanks in advance guys!
Old Dec 2, 2007 | 02:01 AM
Dakine's Avatar
Concept in Motion Crew
yeah i saw those ebay ones also. i say go for the pvc one.
Old Dec 2, 2007 | 04:02 AM
kidwolf908's Avatar
Yea I think I'd risk the SQ drop just for the peace of mind that they would never fall apart...
Plus, how can PVC be negative? What's the difference?
Old Dec 2, 2007 | 04:16 AM
Thermalzeal's Avatar
SOllld for $20 shipped.
The best way to use MDF is by getting an extra can of paint and doing it several good sprays. This is an easy solution for those whose time = money.
Old Dec 3, 2007 | 03:01 PM
Keeshwah's Avatar
Never heard of PVC being used, but I've heard of HDP (High Density Plastic) being used. It's found in cutting boardings and it's stronger and sturdier than MDF. You're not risking SQ loss with it, it's just more difficult to work with.
Old Dec 3, 2007 | 07:44 PM
Imo, the PVC is easier to work with...Its not like its that much harder to drill into it or anything, Plus im liking the extra circular ring for the metal shroud on the speakers. I think I'll get these instead of edeads set they got goin on.
Old Dec 3, 2007 | 08:18 PM
Keeshwah's Avatar
i like using hurricane nuts so i can swap out drivers and i dont know if something similar can be used on plastic.
Old Dec 3, 2007 | 08:31 PM
SePaTc's Avatar
MDF is pourous and is not "sealed". ie, if u want to protect it from weathering and the elements, all u need to do is spray with a thin coat of polyeurethane and let it dried. MDF is now sealed and resistant to expanding, cracking, bowing, etc...
PVC cracks and will vibrate/flex more than mdf. also, isn't really a good sound deadening/proofing material.
but hey, they're only component speaker baffles, probably won't make too big a difference.
Old Dec 3, 2007 | 11:39 PM
nodsetse's Avatar
If you're really concerned you could mount them in the kick panels instead. Then you wouldn't have to worry about water, and you'd greatly improve SQ, compared to the door mounting location.
Max
Oct 26, 2015 12:33 PM
ChefRaekwon
Feb 20, 2006 03:44 AM
ChefRaekwon
Scion tC 1G ICE & Interior
34
Feb 17, 2006 02:00 AM
Makaveli
May 6, 2005 03:43 AM
Rails
Apr 13, 2005 04:50 PM
