E-Brake Light Issues
Old Dec 10, 2007 | 03:33 AM
JPsTc's Avatar
1UP Crew
Default E-Brake Light Issues
Ok, so this isn't the first time this has happend. My E-brake works fine, however, under moderate acceleration the e-brake light pops on. This happens just about all the time. I had the e-brake tightened about a month ago and that solved the problem...but only for a little while because now its back. Any help?
Old Dec 10, 2007 | 03:39 AM
gcxandy's Avatar
how many miles you have on your car, the light comes on when your brake pads are almost done or the brake fluid is low.
draxcaliber's Avatar
search.
means either your brake pads or brake fluid is low. have both checked, replace whatever is necessary, and please search.
Old Dec 10, 2007 | 03:44 AM
Aroddalobster's Avatar
maaaaaaaaany threads on this issue.
Old Dec 10, 2007 | 03:47 AM
JPsTc's Avatar
1UP Crew
^ah thanks guys. Did'nt remember seeing any threads on this and didn't bother to search but I know better for next time . Thanks again
Old Dec 10, 2007 | 05:17 AM
phoenix_2o1_rising's Avatar
i had the same issue, mine turned out to be low level of fluid in brake fluid reservoir... reason being under acceleration, your front end actually picks up, like the angle of the engine bay changes, and the reservoir is like any other tank in the car and has a sensor that detects levels, so when you accelerate it reads in the reservoir as being low since most of the fluid is pushed away from the sensor.. so my advice is check that first after making sure its not the E-brake
Old Dec 10, 2007 | 07:23 AM
SquallLHeart's Avatar
there's a low level because your brake pads are pretty much in need of replacing.
don't fill up that tank whatsoever before checking your pads...
covered alot already.
[/thread]
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
AdmirN
Jan 5, 2015 10:19 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
TheTripleC
Jan 4, 2015 06:46 PM
rolex87
Oct 2, 2003 04:31 AM
