help! strange sound....ideas?
Old Dec 10, 2007 | 05:10 PM
locondcoco's Avatar
Default help! strange sound....ideas?
so lately, i've been hearing a weird sound from the suspension, specifically coming from the rear driver's side. it happens basically when i go over a bump or quick hill or dip, where the springs decompress and then compress again.
it sounds sorta like an old spring matress. any ideas on what it is?
i've jumped up and down in the trunk to bounce the car but could not reproduce the sound. so it appears it needs to be somewhat violent bump or dip. i've also jacked it up to take a look underneath, and everything looks normal.
TIA for the help.
Old Dec 10, 2007 | 06:54 PM
HR_Guy's Avatar
That's funny, I had this same problem just a couple of weeks ago. Going over speedbumps and the back of my car would make a horrible creaking sound.
The dealership ended up putting silicone over the rear bushings and adjusting the TRD rear sway bar.
Old Dec 10, 2007 | 07:04 PM
locondcoco's Avatar
yea, horrible is right.
so has the sound come back?
Old Dec 10, 2007 | 07:42 PM
HR_Guy's Avatar
No. It's been quiet so far. He said it was a permanent fix and that he's seen many tC's this winter with the same problem. Not sure if you have a sway bar, but I changed mine from race to street per the tech's recommendation.
Old Dec 10, 2007 | 08:12 PM
locondcoco's Avatar
yea, i have the TRD rear sway bar as you do. hmm...i'll take a look into it.
Old Dec 10, 2007 | 08:16 PM
nyr197's Avatar
My TRD rear sway bar developed a similar sound over bumps, I took the bushings off and put some quality grease in there, no sound since.
Old Dec 10, 2007 | 08:23 PM
locondcoco's Avatar
if i were to go to an autozone (or similar store) can i buy it there? and what exactly would i be looking for?
Old Dec 10, 2007 | 08:50 PM
draxcaliber's Avatar
yeah, actually, that happened to me when i put on my trd suspension, the front sway bar bushing went bad, and it went away when i replaced them with the hothckis sway bars.
so check your sway bar bushings.
Old Dec 10, 2007 | 08:53 PM
HR_Guy's Avatar
If you're still under warranty they should do it for free. If not you can buy white grease, it should do the trick. Also you can spray the bushings itself with a silicone spray.
Old Dec 10, 2007 | 09:00 PM
locondcoco's Avatar
i dont believe i'm still under warantty, about to hit 40k. plus i bought the sway from trdSparks and i installed it myself. doesnt sound like a hard fix, just to find the time (and warm weather) in order to do it.
thanks for the help guys.
Old Dec 10, 2007 | 09:02 PM
Skeletor's Avatar
i have a creaking sound too,all stock except for tein-htechs
Old Dec 10, 2007 | 09:03 PM
SeanJohn's Avatar
I don't have TRD sway but I know of the sound your talking about. I think i might just buy hothckis sways.
Old Dec 10, 2007 | 09:08 PM
yeah, i was told that the bushing went bad because of the lower rideing height or whatever, new bushings aren't expensive, i think the dealership quoted me like 22 dollars, but i just really wanted the hotchkis set, so i got them.
Old Dec 11, 2007 | 04:24 AM
aRucard's Avatar
i got the same problem, every time i go over a bump or dip i hear a wierd sound coming from the suspension as you said it sounds like and old spring matress and i'm completly stock, could it be the springs?
Old Dec 12, 2007 | 03:23 PM
locondcoco's Avatar
input from anyone else?
Old Dec 12, 2007 | 03:28 PM
tC4italy's Avatar
I thought I had blown a shock????
Loco do you have trd springs/shocks too or just a rear sway?
Old Dec 12, 2007 | 03:36 PM
locondcoco's Avatar
trd springs, trd rear sway and stock shocks.
Old Dec 12, 2007 | 03:49 PM
tC4italy's Avatar
ouchie. Yeah well this thread helped a lot, now I know what to tell them to get checked. ;)
I'll post up when I find out
Old Dec 13, 2007 | 12:49 AM
Skeletor's Avatar
so the problem could be the bushings,is that what everyone came to?
Old Dec 13, 2007 | 01:07 AM
tC4italy's Avatar
bushings
or shocks
